'92 Accord leaks oil from behind engine by firewall, need help fixing.
Old Apr 29, 2004 | 09:57 PM
SR20 Inside's Avatar
Default '92 Accord leaks oil from behind engine by firewall, need help fixing.
I picked up an accord with 157k that runs awesome but it seems to leak oil from right around the oil filter and the oil pan and drips down on the Y in the exhaust. Are there any problems people have with the gasket around the oil pan not sealing properly or any problems with the filter? Anyone have any other ideas on what it might be?
TIA
Modified by SR20 Inside at 5:02 PM 4/30/2004
Old Apr 30, 2004 | 02:15 AM
bill-71SS's Avatar
Default Re: '92 Accord leaks oil from behind engine by firewall, need help fixing. (SR20 Inside)
oil sending unit is right above filter,is that leaking?,also check the filter housing.
Old Apr 30, 2004 | 07:27 AM
AngryTroll's Avatar
Default Re: '92 Accord leaks oil from behind engine by firewall, need help fixing. (bill-71SS)
The oil pressure switch is in that area but the switch usually only leaks through the connector and this is only a small leak. It sounds like something is puking oil. Has the vavle cover recently been removed? Did the gasket slip and tear?
I can't remember if the '92 has the oil cooler ('90 and '91 has it). If it does, it will be behind the oil filter (the oil filter screws to it). There is an o-ring that seals the cooler to the engine block. Clean the area with brake clean and look for the leak behind the cooler. This will usually be a big leak because it seals engine oil pressure. So, if your engine produces 80 psi of oil pressure in the morning, the o-ring will see 80 psi.
Old Apr 30, 2004 | 08:04 AM
It looks like teh gasket around the oil pan might be in bad shape letting oil out and I am going to try to see if there is a problem with the filter sealing up. I'll try to get some pics if I can't fix it so you can see what I mean . Thanks.
robertm2
Jun 2, 2021 10:35 AM
chiaxi2002
Apr 9, 2010 08:56 PM
Acco12dv6
Oct 2, 2006 10:14 AM
96coupe
Dec 18, 2005 01:14 PM
jcpegg
Mar 9, 2005 08:38 PM
