sway bar ???
ok I am planning on getting a itr rear sway bar for my 98 integra rs.. and I know what I need for that swap.. but what do I need to install a gsr front swaybar into my rs?? has anyone done this before I did do a search and came up with nothing.. thanks..
Haven't done it personally, but until someone who has mentions something... I think it'd just be the swaybar itself, the larger diameter inboard mounts, and endlinks.
This was recently discussed on the Tech forum - https://honda-tech.com/zerothread?id=80775
Here are the items that you will need:
1.) GS-R/Type-R 24mm front swaybar
2.) GS-R/Type-R endlinks and endlink bushings
3.) 24mm swaybar bushings and brackets
You will not need to change to the inner arm as illustrated on the diagram since the RS/LS already has a front swaybar.
mynameizstitch
Jul 20, 2009 09:39 PM
navin
Oct 29, 2002 05:04 PM
mamaboy
Oct 29, 2001 10:30 AM
