auto/man convert....Just look
Ok i no this has been coverd 91823904812394081234's of times but i cant find the exact answer i need.
My car 96 LS
Ive installed pedals and clutch system. i got a gsr full swap from a freind with a busted tranny for 1300 but i got another tranny for 600. So my question is what do i need to do about the wiring. Im going to get a obd2-1 jumper harness. Do i need to do any extra wiring since my engine harness is setup for non vtec. And whats involed to get reverse lights to work and be able to remove the key???
My car 96 LS
You'll need to wire up the VTEC solenoid, pressure switch, knock sensor, secondary butterflies, and some other stuff if you plan on using the LS engine harness. The reverse light sensor is on top of the tranny. As far as removing the key, we didn't have any issues with it in an EG we swapped recently, but I'm not sure what exact wiring was involved.
just wondering, if you are getting a gsr swap and putting in a manual swap, why not just get a gsr? You can get an older one for a decent price.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra4lyfe »</TD></TR><TR><TD CLASS="quote">just wondering, if you are getting a gsr swap and putting in a manual swap, why not just get a gsr? You can get an older one for a decent price.</TD></TR></TABLE> well if these prices are correct, then hes getting a better deal doing the swap it will be cheaper
well look at it this way. I bought my car for 1800 with full gsr interior. Im buying the full gsr swap for about 2000 so thats about 3800. So i think im getting a much better deal then buying a real gsr. but anyway. Is it possible to use the d series harness that the motor is coming out of since its already setup for gsr vtec components?
JV
Oct 23, 2003 07:07 PM
