91 Civic 4door Conversion to 92-95 wiring
Old Apr 29, 2004 | 05:35 PM
vtec4gcivic's Avatar
Default 91 Civic 4door Conversion to 92-95 wiring
Im converting a 91 civic 4 door, and using a 92-95 harness, i was wondering if i can just cut the lights and everything of the 92-95 harness, they are not needed, no heater controls or anythings just motor. Is cutting and taping of ends going to mess up the harness????
Old Apr 30, 2004 | 08:14 AM
VTECVillain's Avatar
Default Re: 91 Civic 4door Conversion to 92-95 wiring (vtec4gcivic)
It will require some good wiring skills and a few headaches along the way but it can be done. It would be best to use both the 92-95 engine and cabin harnesses. Since you are eliminating the lighting, heat, etc. it will make for less wiring, just arm yourself with the 91 and 92 Civic Helm's electrical manuals and git-r-dun!
Turbo O
Aug 6, 2007 03:36 PM
digitalcongo
Apr 8, 2005 04:03 PM
