Oil In PCV and valve cover lines
Old Apr 29, 2004 | 05:22 PM
555R's Avatar
Default Oil In PCV and valve cover lines
quick question
will oil in the PCV valve and valve cover vacuum lines be a big cause for a smoky exhaust?
I swapped out a buddies PCV and other lines and found some oil in those lines
any thoughts?
Compression test found 265-270 avg across all 4 cylinders so I doubt its rings
his car smokes on acceleration but the back of the car isnt oily just sooted up
no plugs are oily either
threats thoughts opinions ideas etc
Old Apr 30, 2004 | 09:12 AM
555R's Avatar
Default Re: Oil In PCV and valve cover lines (555R)
noone?
Old Apr 30, 2004 | 09:13 AM
StyleTEG's Avatar
There is supposed to be oil in the PCV lines. The PCV recirculates blowby vapors.
And yes, a clogged PCV system can cause burning of oil.
Old May 2, 2004 | 07:34 PM
555R's Avatar
Default Re: Oil In PCV and valve cover lines (StyleTEG)
did i mention it was alot of oil
that little oil box was all gunked up
the valve was also gunked up and quite a bit of oil came out so I replaced all the lines
when I get a chance im going to remove and clean out that oil box
any thoughts about the IAC also if there might be oil in there too
Old May 16, 2004 | 06:55 PM
CiH22vic's Avatar
Let me know what the outcome is I have the same problem planning to do the same thing
Old May 16, 2004 | 09:45 PM
b19coupe's Avatar
Another source of oil in the combustion chamber is valve guide seals. May not be your problem, but it's possible.
Old May 19, 2004 | 10:58 AM
CiH22vic's Avatar
Default Re: Oil In PCV and valve cover lines (b19coupe)
YEAH IT DOESN'T BURN ON STARTUP THAT'S THE THING, JUST AT IDLE USUALLY
Yodi71
14
May 11, 2014 01:50 AM
Set O' Nines
Oct 30, 2012 07:49 PM
SkoundrelUSA
15
Oct 31, 2006 06:27 PM
AllMotorMark
Apr 8, 2004 06:45 AM
