car hardly idles-H23/vtec
Old Apr 29, 2004 | 04:34 PM
b18c1civic95's Avatar
Default car hardly idles-H23/vtec
okay so i got the car to finally idle without giving it gas but it doesnt do it for long. it idles very very low-(No tach) it seems to run better when its warmed up which i have to help it get to that point. ive searched through dozens of threads and tried different things. I pulled the vacuum line from the FPR and it was wet on the end from gas. and after i did that one time it idled like a normal car. Would this cause the gas in the oil. the compression checks out and the distributor seems okay as far as the cap,rotor,coil are conserned. plugs are also good..... only check engine light i have is for vtec. ?? anything else i should check.....im gonna go and see how it drives around the block......okay make that just down the street and back i dont wanna push it back its pretty damn hot out...
Old Apr 29, 2004 | 04:43 PM
Default Re: car hardly idles-H23/vtec (b18c1civic95)
drove the car.....it takes a sec to get going because its missing but once i do it drives fine and has POWER......
Old Apr 29, 2004 | 09:12 PM
TTT
Old May 1, 2004 | 08:49 AM
bump for the man with strep throat who sat in the E.R. allllll night
Old May 4, 2004 | 05:19 AM
Sam1am26's Avatar
I don't know but bump for a fellow H23 VTEC...
taisho
May 20, 2008 11:47 AM
brownpride016
Nov 9, 2007 07:31 AM
bboychris
Oct 14, 2002 08:25 PM
yellowbuffalo
Apr 16, 2002 06:47 PM
Jesse H
Mar 18, 2002 05:43 AM
