Vaccum lines, mine are all mixed up. Please help
Old Nov 1, 2001 | 10:53 PM
4G-CIVIC's Avatar
New User
Default Vaccum lines, mine are all mixed up. Please help
I must have mixed up the vaccum lines or something but basically I hooked my lines and now my car runs like ****. I need to know where the line coming out of the rear drivers side of the intake manifold hooks up, where the evap purge line connects and then the vaccum line coming out of the charcol canister hooks up.
I thought I tried all the combos but it still does run right. When I shut my car off, it knocks really bad too.
Thanks in advance.
Old Nov 2, 2001 | 05:07 AM
rioninja's Avatar
Default Re: Vaccum lines, mine are all mixed up. Please help (4G-CIVIC)
The map sensor (one on the left) goes into the throttle body. The evap goes into the back of the manifold. Is this a stock motor?
Old Nov 2, 2001 | 05:20 AM
91sifreak's Avatar
New User
I have the itr manifold on my car and that line got capped off after everything that i had tried and i works nicely now. Let me get a pic of mine and I will post it for you to base yours off of hope this helps alittle are you running a b16a b18c1 stock????
good luck
Old Nov 2, 2001 | 10:16 AM
4G-CIVIC's Avatar
New User
Its a B16a gen1. I did a search and found the wiring diagrams. This seems to be a very common problem that people have.
Thanks guys
Old Nov 2, 2001 | 10:50 AM
rioninja's Avatar
I made this up -real- quick, but it should give you a basic idea. Sometimes you need to buy a T-fitting to get everything hooked up right, but other times there will already be enough available ports on the motor. Hope this helps a little. Any q's just ask.
[Modified by RioNinja, 2:51 PM 11/2/2001]
Old Nov 2, 2001 | 01:06 PM
wuhungsixxx's Avatar
New User
Default Re: Vaccum lines, mine are all mixed up. Please help (RioNinja)
jeez bustin out with the diagrams and ****...good lookin out...hehe
Old Nov 2, 2001 | 09:23 PM
One8Hatch's Avatar
New User
hey whats that circle peice on the bottom ot the t fitting? thanks
Old Nov 3, 2001 | 06:07 AM
rioninja's Avatar
Default Re: Vaccum lines, mine are all mixed up. Please help (One8Hatch)
Crappy Diagram, but thats supposed to be the fuel pressure regulator.
Old Nov 3, 2001 | 07:17 AM
91sifreak's Avatar
New User
Damn ninja way to break it down man, good job, sorry could find my damn camera, but ninja got it all right.
Old Nov 3, 2001 | 08:20 AM
rioninja's Avatar
Default Re: Vaccum lines, mine are all mixed up. Please help (91sifreak)
I had a lot of problems when i did my first swap, and i couldnt really find any info on the vacuum line stuff. A handful of swaps later, i guess i got it down pretty well
90Rexx
Mar 11, 2009 05:59 PM
d_SUPAl1l
Nov 21, 2006 07:39 PM
agy2k2
Aug 11, 2006 05:30 AM
.David
Jun 8, 2004 01:10 PM
FredoSP
Apr 12, 2004 09:21 AM
