Too big a wire for wiring Vtec?
Old Apr 29, 2004 | 03:54 PM
soundman's Avatar
Default Too big a wire for wiring Vtec?
Ok I just finished my B16A1 swap in my CRX, and I had some 14 gauge wiring laying around so I did all my wiring with that... The first problem I had was when the VAFC was hooked up, it threw a code the whole time for the Vtec Solenoid, then, I took the VAFC off and just hooked the line up to the ECU, and that worked with no codes for a little bit, but then as I was driving (about 3 minutes) I tripped a CEL and that happened with my 2nd oxygen sensor too... Did I use to big of a wire thus raising the impedance, and causing me to trip a code after a bit, or is it something else?
Old Apr 29, 2004 | 07:53 PM
soundman's Avatar
It's probably not the wire, but why would it work some of the time, and then throw a code, and still work?
Old Apr 29, 2004 | 10:29 PM
wtsexton's Avatar
Default Re: (soundman)
A short in the wiring.
Old Apr 30, 2004 | 05:42 AM
Davep's Avatar
Default Re: Too big a wire for wiring Vtec? (soundman)
if it's wired correctly the gauge of wire doesn't matter, i'd check your wiring.
Old Apr 30, 2004 | 06:22 AM
soundman's Avatar
Yeah I definitely could have messed up the wiring becuase I am not a wiring guru, however, I just dont understand how it will work fine, then throw the code later...
Old Apr 30, 2004 | 06:44 AM
soundman's Avatar
OK first I have the two O2 sensors mixed up, so that takes care of my O2 sensor code (hopefully) I was throwing a code 4 which is 2nd O2 sensor, so hopefully switching the two will fix that... But I also have a code 21 that lights up sometimes which is Vtec soleniod... So any thoughts on this is appriciated...
Old Apr 30, 2004 | 07:25 AM
crx_88_si's Avatar
it has a vtec in and out doesnt it? maybe those are crossed?
Aposiopesis
Nov 12, 2017 06:18 PM
DeezNutts
Mar 19, 2006 11:25 PM
AzntaggeR
Oct 7, 2005 01:05 AM
csmsi311
Nov 23, 2003 11:02 PM
