No Spark...not so sure its an ignitor...which distroscan I swap (95 gsr)
Old Apr 29, 2004 | 03:30 PM
Jet Black's Avatar
Default No Spark...not so sure its an ignitor...which distroscan I swap (95 gsr)
integra GSR
I installed MSD 8.5 superconductors on my car and it wont spark anymore with MSds or stock wires.
Explination:
Installed cap and rotor, unplugged one of the power connectors to the distro to get the rotor out. (The one with the tach signal and the power)
Installed the MSDs in the wrong order ...started car (never having reconnected the connector completely...I guess it was just touching) Ran like *** (obviously)
Didnt understand and installed the stockers in the right order...ran fine ...figgured the order was wrong with the msds and reinstalled em right. Car never started after this. I noticed the connector wasnt in completely so I thought I had found the problem, but it still wont start.
I checked for spark and I have none. Tested the coil and its resistance is pretty close to spec. I assumed it was the ignitor so I swapped one in from an 89 civic si (according to many posts on here they are the same...I'm not too convinced anymore as the model numbers differ) Still nothing happened.
I'm out of ideas. Next idea is to swap in a dristo from another teg..which ones can I use?
Any other ideas such as voodoo curses or such are welcome.
Integrame
Jul 17, 2008 08:29 AM
1Point8DC2
Aug 20, 2007 12:30 PM
hdeuce
Nov 2, 2005 03:10 PM
QUAIJAI
Jan 27, 2005 04:12 PM
1lost_fella
Feb 7, 2003 09:59 AM
