can't get my left side axle out and or can't break my tranny loose
Old Apr 29, 2004 | 02:35 PM
mrxracing's Avatar
Default can't get my left side axle out and or can't break my tranny loose
yes i'm sure i have all the bolt out that i need out but i can't get my driver side axle out of the tranny so i figured i could pull it out when i start removing the tranny but i can't get it to budge either...any advice would be very grateful..95 ls MT
thank you
Old Apr 29, 2004 | 02:39 PM
Sack Master's Avatar
Default Re: can't get my left side axle out and or can't break my tranny loose (mrxracing)
Grab a pickle fork or a pry bar and pop that thing out. They are always a pain in the butt.
Old Apr 29, 2004 | 02:41 PM
allout_eg6's Avatar
it's always a bitch to take the left axle out of the midshaft you have a pop it out with a fork or something just keep going at it it should pop off
Old Apr 29, 2004 | 02:52 PM
Toda Built's Avatar
Default Re: can't get my left side axle out and or can't break my tranny loose (allout_eg6)
make sure you have the 3 bolts that connect the halfshaft to the block out, the get a flat head (strong one if possible, or one you dont mind bending) and pry the axle out.
Old Apr 29, 2004 | 02:53 PM
LOWNSLOW's Avatar
took me 5 minutes to remove it with a pickle fork. Keep at it. It'll come off eventually. What I did is a light pryed it in a circular motion while slowly pulling at it. It came off after. good luck.
Old Apr 29, 2004 | 03:04 PM
mrxracing's Avatar
Default Re: can't get my left side axle out and or can't break my tranny loose (2Slow2Run)
tahnks for the help guys i'm off to try it now!!
88aeFC3S
Dec 23, 2010 07:43 AM
91EF919
11
Apr 17, 2009 10:56 AM
RevTek 6
Oct 2, 2007 03:41 PM
B18EG6
Jun 24, 2004 04:33 PM
Red_Si
Sep 23, 2003 04:03 PM
