Compression
Old Apr 29, 2004 | 01:53 PM
BoBoChan's Avatar
Default Compression
Wut does the compression ratio mean? like 11:0:1 or sumthin like that. i know.. its a noob question.. if you dont want to answer thats cool.. but dun poke fun.
Old Apr 29, 2004 | 02:03 PM
Sack Master's Avatar
Default Re: Compression (BoBoChan)
Easy answer. It's ratio. Simple mathmatics. You take something that is 11 parts and squeeze it into 1 part. Then you yield an 11:1 ratio. Take from 12 parts compress to 1 and then you have 12:1. Thats just simple way of explaining it. I recommend taking an auto course. Or searching on the net. I can explain the exact working of compression ratio and how it affects the way your car runs but that would take all day. GOOD LUCK
Old Apr 29, 2004 | 05:05 PM
BoBoChan's Avatar
Default Re: Compression (Sack Master)
tyte.. so the bigger difference between the numbers = better..
ef_si
Jul 25, 2013 02:09 PM
SantaAnaFerio
11
Dec 15, 2009 03:06 PM
JDean6pac
Apr 10, 2007 09:01 PM
demonhunterlevin
Jul 18, 2006 11:53 AM
ITR.00-1282
Mar 30, 2003 09:04 AM
