!!! help b16 swap questions!!!!!
Old Apr 29, 2004 | 12:19 PM
grante's Avatar
Default !!! help b16 swap questions!!!!!
i just got my b16 in my 1990 civic 4 door sedan
engine sitting well
did not need passport motor mounts- customized it myself but have serious problem- engine doesn't fire to spark plugs or distributor cap
can I use my stock computer DX?
car turns over but will not fully start
need advice in the next 24 hours- how can I start the engine?
V-tech silinoid is connected to stock computer
**** this bullshit, what's wrong?
ordered 249 dollar distributor cap- gets put on at 800 AM
88-91 i hope the distributor is the problem the guys dont really know what to do axles are in im stuck on the last step some one help
Old Apr 29, 2004 | 01:26 PM
95DXCIVIC's Avatar
Default Re: !!! help b16 swap questions!!!!! (grante)
pretty sure your going to need a different ECU, take a quick search for and look on what you need for b16's. I think you will need a P28 ECU for your swap, Good Luck.
Oh yah, its vtec
Old Apr 29, 2004 | 01:31 PM
spaceman's Avatar
$249 for a distributor cap?...i think you mean the complete distributor..is it a jdm b16?
Old Apr 29, 2004 | 01:39 PM
kur0ryu's Avatar
if this is a JDM B16A (88-91), you'll need a PR3 or PW0 ecu.
Old Apr 29, 2004 | 01:57 PM
DC 2's Avatar
Default Re: !!! help b16 swap questions!!!!! (kur0ryu)
If your not running the correct ecu that could def be your problem. Make sure you connected all your grounds.
Old Apr 29, 2004 | 03:11 PM
APEX CRX's Avatar
I know you're frustrated but if you don't have all the info/knowledge on this swap you're gonna need more than 24 hours.
1. you need to use a PR3 or PW0 ecu to run your B16a
hit up member >blackwagon he has 2 PW0's for sale
2. you need to get your wiring correct. there's no way you could of hooked up your vtec solenoid to your stock dx computer.
these are your 2 main things to do first. post back up if if you run into more problems after you take care of these issues first
Old Apr 29, 2004 | 04:53 PM
ICeDoUt's Avatar
why didn't u try using your old dizzy?? thats what i did. I heard that it was possilbe so i tried it no harm and its free, and it works, HF distributor on my b16, u can also try swaping out the coil ignitor and any other internal that u think could be busted
sirminder
Aug 21, 2011 02:38 PM
juanintec
Aug 15, 2007 07:37 PM
