shift linkage for DELSOL
The integra linkage will not work. Most dealors can get the linkage from the DOHC del sols ( make sure to say DOHC del sol if you say vtec they will prob send you the sohc vtec ones ) and they will bolt right in, the angle is much different then the integras or 99 si. RageDzine on this site has a shop and i know they stock them. Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK K20 »</TD></TR><TR><TD CLASS="quote">The integra linkage will not work. Most dealors can get the linkage from the DOHC del sols ( make sure to say DOHC del sol if you say vtec they will prob send you the sohc vtec ones ) and they will bolt right in, the angle is much different then the integras or 99 si.</TD></TR></TABLE>
This is true. For any B series swap into a Del Sol, you need to get the Del Sol VTEC (B16A) shift linkage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
This is true. For any B series swap into a Del Sol, you need to get the Del Sol VTEC (B16A) shift linkage.</TD></TR></TABLE>
Eg2707
Feb 15, 2008 12:12 PM
skiracer8148
Mar 17, 2007 05:09 PM
SOLvtec
Oct 27, 2006 09:30 AM
mintscorpion
Jul 17, 2005 11:26 PM
