claying motor head gasket question ????
Old Apr 29, 2004 | 06:10 AM
jdmcx's Avatar
Default claying motor head gasket question ????
I am about to clay my motor ls bottom and GSR head but the only old head gasket I have is from b20s
Could I still use it just to lay the motor? All OEM head gaskets are the same thickness right? Don’t really want to buy a head gasket just to clay the motor
Any help would be great
Thanks
Jason
Old Apr 29, 2004 | 09:27 AM
CHEETAH's Avatar
Default Re: claying motor head gasket question ???? (jdmcx)
yes just clean all debris from the used gasket.
greg
Old Apr 29, 2004 | 07:57 PM
jdmcx's Avatar
Default Re: claying motor head gasket question ???? (CHEETAH)
when i am instaling the new head gasket is it necessary to remove all four brass rings from the head gasket also do i need to clean the new one with anything or just put it on
and what do i use to clean the surfaces of the block and head (just a shop rag?)
Old Apr 30, 2004 | 04:26 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcx &raquo;</TD></TR><TR><TD CLASS="quote">when i am instaling the new head gasket is it necessary to remove all four brass rings from the head gasket also do i need to clean the new one with anything or just put it on
and what do i use to clean the surfaces of the block and head (just a shop rag?)</TD></TR></TABLE>
- no leave brass rings
- blow off with air gun then spray with copper spray
- spray brake cleaner on a rag and wipe top of block/bottom of head
good luck
greg
Old Apr 30, 2004 | 06:10 AM
jdmcx's Avatar
hey greg is the lower timing cover for a ls, gsr, and itr the same i put an itr oil pump on and i need to get a timing cover it is a ls block with a gsr head which lower cover do i use
Old Apr 30, 2004 | 06:31 AM
CHEETAH's Avatar
you can use the ITR or 96+ GSR easier, the 94/95 LS and GSR you have to grid a bit on the bottom to get it to fit properly.
*archive this thread for search engine *
Greg
Old May 7, 2004 | 07:18 AM
jdmcx's Avatar
hey greg i clayed the motor and i can go +6 on the intake but only 0 on the exhaust ever heard of that
Cantcatchme
Jan 5, 2012 03:26 PM
Layziebtnh055
Jun 3, 2004 08:05 PM
rathead
Jul 29, 2003 04:39 PM
boostedel
Apr 6, 2003 09:11 AM
