How to cut and drill into fiberglass 101 ??
Old Apr 28, 2004 | 10:31 PM
xunkn0vvnx's Avatar
Default How to cut and drill into fiberglass 101 ??
I have a 1994 Honda accord and i just purchased a front and rear bumper from GTP international importfan.com. There are two small pieces on my front fiberglass bumper that I want to cut off. The fiberglass is typically sized in thickness.
What should be used to cut this piece of ?? Do i need a special fiberglass cutter ??
and also the kit didn't have the holes drilled for mounting the bumper. What should I know before I start drilling mounting holes into my bumper (splitting, etc.) ?? What is the best way to mark off where I want to drill ??
Old Apr 30, 2004 | 01:11 PM
xunkn0vvnx's Avatar
Default Re: (IronTater)
help ?!!
Modified by xunkn0vvnx at 9:01 AM 5/11/2004
Old May 11, 2004 | 12:01 AM
xunkn0vvnx's Avatar
Default Re: (xunkn0vvnx)
up
Old May 25, 2004 | 12:16 PM
idmspeed's Avatar
Default Re: How to cut and drill into fiberglass 101 ?? (xunkn0vvnx)
No special cutter required. Just make shure you use a fine tooth metal cutting blade. Use a quality blade as well because fiberglass will dull a blade fairly quickly. As for drilling, just use a nice sharp bit. Pre drill wth an 1/8" bit before drilling holes larger than 3/8" just to be on the safe side. Visit our hood scoop installation page for more ideas on how to work with fiberglass body parts. http://www.idmspeed.com/scoopinstall
Old May 25, 2004 | 01:19 PM
Timmy!'s Avatar
use tape were your going to cut to keep it from splintering, Spend the extra money on a good blade.
accord99power
Paint and Body
Feb 11, 2011 11:39 AM
aznkr4zyboi
Paint and Body
15
Jan 10, 2010 02:29 PM
Tigfab
Welding / Fabrication
10
Jan 26, 2007 07:57 AM
LOWLIFEHATCH
Mar 5, 2003 03:56 AM
BoostedB20A
Jan 7, 2003 09:36 PM
