Input JRSC on a ZC
I dont see too many of this engine config, maybe because the supercharger is more than a B16 swap, but... I was thinking of getting a zc swapped ef hatch, and since its got the zc in it anyway, why not supercharge it? has anyone done this reading this post, if so let me know what you think, will it beat a b16 rex? or hatch? thanks for any input (hopefully its positive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SC0TT »</TD></TR><TR><TD CLASS="quote">Ive heard there are issues with firewall clearance.</TD></TR></TABLE>
Ive heard the same but with B16s, Ive seen one zc swapped with a supercharger, but i never thought to ask about this.
Jackson sells a ZC blower listed as 86-89 Integra. Its a Bigger blower with a D Manifold.. I dont think there is a issue the ZC it does not sit that much closer to the Firewall than the D16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraXSi »</TD></TR><TR><TD CLASS="quote">Jackson sells a ZC blower listed as 86-89 Integra. Its a Bigger blower with a D Manifold.. I dont think there is a issue the ZC it does not sit that much closer to the Firewall than the D16</TD></TR></TABLE>
Actually, the one I found is on landspeed racing.com, and it listed 88-98 ZC non Vtec heres the link
http://www.landspeedracing.com....html
nobody has one of these setups? More importantly in my area for a ride in it? Id buy Micky D's!!! Also would like a ride in a B16 rex or Ef same food buying would apply
yes someone does have one of these setups!! go to thezcr.com and ask crxrocks about it. he has a twin cam zc with a jrsc kit in it. jrsc actually makes kits for zc. just go on their site and do a search on zc
For the amount of $$$$ I would get one
No way of Cooling intake charge other than Expensive Water injection
I say go Intercooled Turbo kit and you'd be happier
But doesnt the supercharger run off of intake? Intake should be cooler than exhaust right? Plus the advantage of boost off the line as opposed to turbo spool is what i like.
A supercharger runs off the crank with a pulley & belt. Regardless of what you're using to do it, any time that you compress air, it creates heat. A turbo allows you to cool the air coming out of the turbo after it has been heated by passing through an intercooler. A centrifugal supercharger will allow you to do the same thing by using an aftercooler (basically works the same, you can have air/air or water/air versions). A roots-type like the Jackson cannot cool the air since it is sitting directly on the motor. It's basically like if you took a turbo and attached it directly to the IM, there's no where for the air to be cooled. That said, a roots-type is a good choice for mild-boost applications like street cars and autocross cars. For big power gains, you need to go turbo or centrifugal s/c. The turbo is then going to be the better choice for efficiency. With any supercharger, you have to use power to create power. Since a turbo runs off the exhaust flow, you're not really using any engine power to run it. That's why you see more people going turbo now than anything else, it's easier to get more power out of it.
Don't take this as saying "don't get the jackson". I'm considering one myself since I'm not looking for a ton of power (150-160 whp tops out of my z6) and I'm primarily going to use it during autocross where too much power would hurt me in a lightweight crx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave421 »</TD></TR><TR><TD CLASS="quote">A supercharger runs off the crank with a pulley & belt. Regardless of what you're using to do it, any time that you compress air, it creates heat. A turbo allows you to cool the air coming out of the turbo after it has been heated by passing through an intercooler. A centrifugal supercharger will allow you to do the same thing by using an aftercooler (basically works the same, you can have air/air or water/air versions). A roots-type like the Jackson cannot cool the air since it is sitting directly on the motor. It's basically like if you took a turbo and attached it directly to the IM, there's no where for the air to be cooled. That said, a roots-type is a good choice for mild-boost applications like street cars and autocross cars. For big power gains, you need to go turbo or centrifugal s/c. The turbo is then going to be the better choice for efficiency. With any supercharger, you have to use power to create power. Since a turbo runs off the exhaust flow, you're not really using any engine power to run it. That's why you see more people going turbo now than anything else, it's easier to get more power out of it.
Don't take this as saying "don't get the jackson". I'm considering one myself since I'm not looking for a ton of power (150-160 whp tops out of my z6) and I'm primarily going to use it during autocross where too much power would hurt me in a lightweight crx.</TD></TR></TABLE>
Well thats what I want a relatively fast and reliable street car, obviously Im not very fluent in turbo or sc tech, I know some basics, but not enough to put a turbo on a car and drive it everyday, Ive read up on the Jackson, and from what Ive read its pretty user friendly. Now do I get one of these or spend the money on B16? decisions decisions
But thanks for that info it does help. Keep it coming I appreciate it
I've drove a few JRSC cars, and everyone I've ever drove I've been very unimpressed. For the amount of money you spend you can easily create your own turbo kit for half the price and make more power, and have real fuel management. A ZC turbo tuned well running 10psi can put down over 200whp and smoke the **** out of NA b16's
Heres a video of my buddy (filiming) its a 12sec ZC racing me (in the red crx) Twin turbo ls/vtec.
http://www.nw1320.com/media/local/HTmeet.wmv
As you can see he pretty much hangs with me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHatchSOHC »</TD></TR><TR><TD CLASS="quote">jackson now sells a ZC supercharger just so yall know....</TD></TR></TABLE> yeah I have a link to a place selling in an earlier post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbaZ »</TD></TR><TR><TD CLASS="quote">I've drove a few JRSC cars, and everyone I've ever drove I've been very unimpressed. For the amount of money you spend you can easily create your own turbo kit for half the price and make more power, and have real fuel management. A ZC turbo tuned well running 10psi can put down over 200whp and smoke the **** out of NA b16's
</TD></TR></TABLE> Dude kick *** video, I loved the speedo shot, looked almost like a crotch rocket speedo, Everett eh? Im from Port Orchard, was the footage in Seattle area, the highway looks familiar. Well I really would like to take a ride in a SC civic or rex, and a b16 rex, again I know nothing about turbo tuning etc. so I think it would be a bigger pain in the *** for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraXSi »</TD></TR><TR><TD CLASS="quote">I would just go with a turbo setup. Cheaper and better power.. and with good turbo sizeing up can "almost" get rid of lag</TD></TR></TABLE>
Where do you get cheaper? After all is said and done I think a turbo cost more than 2500 bux, maybe if you made a turbo kit, but that takes know how, which I dont, plus factor in the tuning and from what i hear turbos can get finicky on muggy days, hot days etc, the Jackson racing is way more user friendly from what Ive read, Im the type of person who needs user friendly.
And trust me there is a ton of BS about the jrsc out there.. Hell if you want to buy a "kit" You can pick up a greddy SOHC kit for less than 2000. Most SOHC kits (zc is a d motor) are cheaper. And any FI your going to have issues all and all your still forcing air in to the engine so you can have the same issues with a JRSC as a turbo.. And if you can pick up a JRSC for less that 2500 new your doing good
Either way its always gonna be easier to tune a turbo. A supercharger is limited in what you can do, but it is very user friendly. Last I saw those JRSC are what, 3 grand? You can make a decent custom turbo kit from that and learn a hell of a lot more.
From: spinning DnB till your head explodes,jersey/philly
if u had the time and know-how u could prob make a turbo kit for easily half the price of the sc kit and be much happier in the end. but if ur not looking for huge power gains maybe the 3k jrsc will suit u fine.
boosted D series dominate all but very heavily built NA b series engines
Boosted D > NA B
my turbo y7/z6 @ 10 made a fool of my friends del sol VTEC with zex stage 2 cams, 8lb fidanza flywheel, type r clutch, type r intake manifold, skunk2 valve train, PYR chip (p28), iceman CAI, DC 4-2-1 header, exhaust
Boosted D > NA B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwissChEz82 »</TD></TR><TR><TD CLASS="quote">Either way its always gonna be easier to tune a turbo. A supercharger is limited in what you can do, but it is very user friendly. Last I saw those JRSC are what, 3 grand? You can make a decent custom turbo kit from that and learn a hell of a lot more.</TD></TR></TABLE>
Once again Folks consult this link, JRSC Kit for zc 88 up $2495 less than 2500 (barely) and WAY less then 3gs and I did a mock checkout to see S&H and I think its included in cost. heres the link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicminded73 »</TD></TR><TR><TD CLASS="quote">
http://www.landspeedracing.com....html</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=748967
92-95 Ex/Si - $1445 shipped
92-95 Ex/Si
Large - $810 shipped ($1069 Retail)
Standard - $630 shipped ($849 Retail)
If you dont feel good about making your own kit
All you need is the standard intercooler soo 2075 shipped... this is way better than the JRSC for less ... Damn now I want one....
92-95 Ex/Si
