clutch for my application?
Old Apr 28, 2004 | 07:37 PM
hi mom's Avatar
Default clutch for my application?
Well just today I dropped my 95 RS off at the shop to get a b16a head thrown on my B18B block, along with AEM cam gears, AEM intake, Tanabe Race Medallion exhaust, Test Pipe.. and JDM 4-1 header
I do a lot of autocross, my car is stripped like mad in the back, along with a cusco cage..
I drive my car everywehre, to highschool, out with friends and on the weekends to events..
I know the power of the setup will kill my "almost already" dead stock clutch so Im trying to find something that will fit my application..
Any suggestions would be greatly apprecaited.. Im still learning and plan on building my engine within the year so I might need something to be able to work with my already 180HP and my HP after the build..
Old Apr 28, 2004 | 09:55 PM
pakman2002's Avatar
Default Re: clutch for my application? (Kid RS)
I don't know enough to direct you to your desired answer but... I can tell you what you did wrong in your post. People on HT usually don't smile upon the others that dont DIY it.
Old Apr 29, 2004 | 05:06 AM
hi mom's Avatar
Default Re: clutch for my application? (pakman2002)
ayy.. I would do the swap if I knew how, I got a great deal and I wanted to get it done asap.
neways, bump for clutch
Old May 12, 2004 | 07:56 AM
notsure's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pakman2002 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know enough to direct you to your desired answer but... I can tell you what you did wrong in your post. People on HT usually don't smile upon the others that dont DIY it. </TD></TR></TABLE>
I dont see a problem with admitting that the task is outside is skill/knowledge set. I certianly would not want to rip off my head and slap a vtec head on MY car with just a socket set and a helms.
To the thread starter, just search "clutch" in the integra, allmotor, hybrid and tech forums and look for similar setups. then go to classifieds and the sponsers forum and look for whatever you choose for your setup.
Old May 12, 2004 | 08:12 AM
nickgmiller04's Avatar
from what ive read, you do not want any kind of "pucked" clutch. you want a full face disk to maintain driveability. and you probably dont want a xtrem pressure plate w/ 100000x the clamping force of stock.
i would look into an action kevlar face clutch. they seem to last forever. i think thats what im going to get when i rebuild my engine. some sponsor here sells them. light fw might benefit you also
hksturbolude
Jun 4, 2004 04:08 PM
ih8danoles
Oct 7, 2002 04:08 PM
ZCVTEC-SOHC
Apr 17, 2002 11:40 AM
EleanoR
Aug 4, 2001 07:51 AM
