-bad lag in power at constant R's
when i'm cruisin at a constant rpm..my car has this studder...it bucks slightly...and has a bad lag in power down low...any ideas?
also...another problem...my lights flicker from bright to dim....any ideas on that?
-Mike
-Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inJDMtegra »</TD></TR><TR><TD CLASS="quote">when i'm cruisin at a constant rpm..my car has this studder...it bucks slightly...and has a bad lag in power down low...any ideas?</TD></TR></TABLE>
Sounds like a possible O2 or TPS problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">also...another problem...my lights flicker from bright to dim....any ideas on that?</TD></TR></TABLE>
Could be the alternator or a possible short in the wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
Could be the alternator or a possible short in the wiring.</TD></TR></TABLE>
Your problem sounds similar to mine, my dizzy took a **** the next morning on the way to work. I hope it doesn't happen to you. Pop open the cap and check for red dust. If it's there, replace that thing right away.
illmatic520
Jan 23, 2008 07:21 PM
RsxType-Stitch
16
Sep 7, 2005 07:52 PM
