Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
225's on an EG?
Old Nov 1, 2001 | 05:05 PM
rambler's Avatar
New User
Default 225's on an EG?
I'm wondering if anyone has run a 225 on an EG (street mod) hatchback?
Does it require spacers?
What wheel offset?
The specs below are taken from the Hoosier Website. http://www.hoosiertire.com/rrtire.htm
The same sizes are available in the new Kumho as well.
P225/50ZR-14
Tread Widty 8.8"
Diameter 22.7"
Circ. 71.3"
Recomended Rim 8-9"
Measured Rim 7"
Section Width 9.2"
P225/45ZR-15
Tread Width 8.6"
Diameter 22.8"
Circ. 71.6"
Recomended Rim 7-9"
Rim Width 7.5"
Section Width 9.3"
I am contemplating wheel and tire size for AutoX next season and am starting my research. Any and all comments are welcome.
Damn I wish they made a lower profile tire (translation smaller diameter) in a 14 or 15.
PS. I am stuck with a 14" or 15" wheel due to brake size.
Old Nov 1, 2001 | 05:33 PM
KekeK-18's Avatar
Default Re: 225's on an EG? (rambler)
I'm running 225 45 15 Hoosiers in the Front and 205 50 15 in the rear on my EG. the front tire will touch the inner wheel well a little during full lock but not really an issue. the 225 Kumhos are little narrower and should be fine also.
Old Nov 2, 2001 | 11:45 AM
johng's Avatar
I'm not sure of his wheel off-set, but Roger Foo was running 225/50-15's on his WC Civic with 10mm spacers.
Old Nov 2, 2001 | 12:39 PM
chad's Avatar
Moderator
looks like i'm gonna have to get me some 225!!
Old Nov 2, 2001 | 02:26 PM
KekeK-18's Avatar
Default Re: 225's on an EG? (johng)
I'm running 42 offset 15x7 volks. Roger is running a 10mm spacer to clear the AP calipers
Old Nov 2, 2001 | 07:46 PM
rambler's Avatar
New User
Default Re: 225's on an EG? (b18cturbo)
What do you all think of a 225/45-15 on a Kosei K1 in 15X8?
At this point that is the plan.
Old Nov 3, 2001 | 05:01 PM
mgent's Avatar
why not 13" wheel? every competitive "eg" that i know of autocrossing (i am assuming this is your sport since you mentioned street mod) in CSP or SM is running the 225's on a 13*7 or 13*8 inch wheel. not only does this make more sense, but the tires are cheaper i believe also! if there is a certian reason you don't want these tell me, cause i'm about to get some 13*7's.
mark
grnaccord
Jan 4, 2019 08:17 AM
ruck
Sep 15, 2009 04:12 PM
Steve_O
Jan 30, 2004 03:03 PM
hybrid_eg
15
Feb 10, 2003 12:59 AM
