where is my filler cap for transmission fluid?
i can't find the filler for auto transmission fluid in my '92 accord. i see 2 areas to fill brake fluid on either side of the engine area each near the back.
the green rectangle around the drive(transmission) indicator on my dash is blinking. does this mean i need fluid?
help!
suanna
help!
suanna
you will need a funnel. it should be on the left side in front really low. the dipstick hole is where you fill it and the dipstick is yellow. you should have to stick your hand far down
your d4 light is flashing that is probably something more serious than just adding fluid. Do you feel any slipping or issues with the tranmission?
make sure your car is hot and running. on level ground shut your car off and check the tranmission fluid within 30 secs of shuting it off. the fluid should be red and not dark brown
I also have a 92. You can check your fluid level with the yellow dip stick towards the bottom front battery side of your engine! Try that and see what you get!
Good luck!
Good luck!
Thunder Cat
Dec 9, 2005 03:39 AM
..::91TEG-G2::..
Nov 15, 2004 05:35 PM
