Susupension squeak
When its cold and I go over potholes or bumps in the road, I get a really loud squeak seeming to come from my rear shocks. I just recently changed them out because they had gone bad (there was sqeak with the old ones too) and I torqued down everything to the specs in the haynes manual, etc. etc. I cant figure it out. Anyone having similar problems, know where the squeak is coming from? I have a 94 ex coupe
Squeaking noise.
I recently started having the same problem. But I am not sure if it due to the suspension.
I get a squeaking noise from the rear end of the car. I am not sure if it from the brakes or some place else.
I recently had a brake pad change. Could it be possible that the squeaking noise could be coming from the suspension.
If you know, I could possibly get my car checked from a dealership.
Brakes probably arent your problem because the rear brakes are used very little in daily driving. When does the sqeaking occur when you are driving?
Jon Petersen
Feb 22, 2018 08:00 AM
