HELP from those with knowledge of Z10 Radius arms
Old Nov 1, 2001 | 03:54 PM
2k1TypeR0610's Avatar
New User
Default HELP from those with knowledge of Z10 Radius arms
I just finished the install tonight. The only thing I need to do is go to Home Depot and get a shorter screw for the center of the cross member. I took my car out and test drove it. When I initially get on it hard there is a loud and distinctive knock. And when I apply the brakes semi emphatically there is the same knock. Is this attributed to the cross member flexing at the central point since I haven't attached the screw or is there something I am overlooking. If this knock is the noise I hear is associated with this kit I will remove them. Please help.
Old Nov 1, 2001 | 03:56 PM
AssPenny's Avatar
Default Re: HELP from those with knowledge of Z10 Radius arms (2k1TypeR0610)
Mine did the same thing untill i got a new center bolt. If you look under the car you will see how much the bar moved. The center bolt is defently needed.
[Modified by AssPenny, 4:57 PM 11/1/2001]
Old Nov 2, 2001 | 08:43 AM
New User
Default Re: HELP from those with knowledge of Z10 Radius arms (AssPenny)
Can anyone confirm if this is the reason for the knocking I'm getting?
Old Nov 2, 2001 | 08:45 AM
Jason's Avatar
apparently Asspenny's response wasn't good enough? I helped w/ his install and I will reiterate what he said...once the center bolt was placed in, it eliminated the sound...get yourself a smaller bolt and you'll be fine!
Old Nov 2, 2001 | 08:57 AM
New User
Default Re: HELP from those with knowledge of Z10 Radius arms (typer98)
Cool, just making sure. I just saw another of his posts claiming that his car was still making a sound and he wanted to have the people that were meeting in S FL this weekend to to see if we could find what it was.
Old Nov 2, 2001 | 09:01 AM
Jason's Avatar
yeah, we finally figured out what the problem was, too much preload was causing his issues...
is it me, or were you the only two that mentioned the center bolt was not the right size??? doesn't make sense to me, b/c there is no way in hell that huge bolt they give for that center bracket is going to fit...
glad we could help...maybe we'll see you this weekend!
BTW, where abouts do you live exactly, as I've been seeing a few R's by me of people that I don't know, and I know about 5-6 R drivers in the area...you can IM me if you don't want to say it on here...
[Modified by typer98, 1:02 PM 11/2/2001]
Old Nov 2, 2001 | 09:10 AM
New User
I'm in the east Fort Lauderdale area. Yeah I've only seen our two posts about the bolt being too long. Also when I called Z10 they told me to thread it through the middle hole on the brace. The only hole I could line up on the brace to the frame was the very first hole, furthest from the bar. Oh well. I only know of Sherbaz and a friend of his with a PY ITR with a carbon fiber hood and a hybrid cold air intake. I've seen a Yellow one driving around in my area but don't know the kid and I also see another yellow one that belongs to someone that works at the Eckerds at 5 points.
Old Nov 2, 2001 | 12:09 PM
Dropspeed's Avatar
Once my Z10 was inplace I just ran the Drill bit size they recommended through the on the center tab and enlarged it as I drilled through the core support. Then I installed the long bolt they supplied.
Mattj
Old Nov 5, 2001 | 04:42 AM
Z10 Motorsports's Avatar
New User
Default Re: HELP from those with knowledge of Z10 Radius arms (Dropspeed)
if you do not place the center bolt in you will continue to hear the knocking sound only cause that bold is a form of support on the radius arms.
Old Nov 5, 2001 | 04:57 AM
New User
Default Re: HELP from those with knowledge of Z10 Radius arms (Z10 Motorsports)
Thanks to everyone. I thought this topic was long forgotten and didn't repost to let everyone know that it was fixed with the bolt. I had to wait to get a smaller bolt though because it would hit the radiator if I used the one supplied. Either way a bolt no longer than 1.5" is needed to secure it to the lower radiator support.
BTW what should you torque that bolt to?
Old Nov 5, 2001 | 05:31 AM
New User
it doesnt have to be torqued that much, about 25-30ft-lbs at the most
Old Nov 5, 2001 | 05:37 AM
Jason's Avatar
glad to hear everything is better!
Old Nov 5, 2001 | 05:50 AM
New User
hey guys whats up,
hey this is off the topic of z10 motorsports but are those clubs still open down there stereo, space and crowbar.
Old Nov 5, 2001 | 03:37 PM
Jason's Avatar
hey guys whats up,
beats the hell out of me...i've only lived here just over a year...I moved from Ocean County, NJ, right by you guys!!!
Old Nov 8, 2001 | 05:24 AM
New User
good job get out of jersey while you still can, jk. thats cool jersey people are too uptight for me. have fun in florida
justin
Old Nov 14, 2001 | 06:37 AM
New User
yup
ludekid4323
Sep 14, 2007 04:46 PM
Vtakkk
Suspension & Brakes
Aug 3, 2006 02:52 AM
oz_zc
Jun 23, 2006 09:20 PM
phyzJunkieCivic
Mar 11, 2006 05:49 PM
Bert
Feb 26, 2002 10:34 AM
