what's in my best interest? OBD1 or OBD2?
Old Apr 28, 2004 | 03:19 PM
elmalouno's Avatar
Default what's in my best interest? OBD1 or OBD2?
i have a 91 dx i am swapping a 96(obd2) gsr motor into... i was planning on running it as obd1 and using a 0bd0 to 0bd1 harness. but i was wondering, after i saw a dx to obd2 harness forsale weather that might be the better way to do it? whats the differences between obd1 and obd2? i am thinking more sensors are involved.. basically i just want to make my life as easy as possible without sacrificing performance from the obd2 motor.
thanks
Old Apr 28, 2004 | 04:23 PM
elmalouno's Avatar
Default Re: what's in my best interest? OBD1 or OBD2? (elmalouno)
up for some advice
Old Apr 28, 2004 | 04:27 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmalouno &raquo;</TD></TR><TR><TD CLASS="quote">i have a 91 dx i am swapping a 96(obd2) gsr motor into... i was planning on running it as obd1 and using a 0bd0 to 0bd1 harness. but i was wondering, after i saw a dx to obd2 harness forsale weather that might be the better way to do it? whats the differences between obd1 and obd2? i am thinking more sensors are involved.. basically i just want to make my life as easy as possible without sacrificing performance from the obd2 motor.
You basically can do it either way. You can still use the OBD2 distributor and injectors. You will only need one 4 wire O2 sensor. It is kinda your call. I prefer the 0-1 method as you can go with Hondata, etc. later on down the road. I build both harnesses and the 0-1 harness is slightly easier to build and install.
Old Apr 28, 2004 | 04:35 PM
elmalouno's Avatar
Default Re: what's in my best interest? OBD1 or OBD2? (Blown90hatcH)
word.. thanks for clearing that up.
u got directions on how to wire the obd2 dizzy and injectors up to the dx harness by chance? i know someones gotta have that info
Old Apr 28, 2004 | 08:11 PM
elmalouno's Avatar
up?
Old Apr 28, 2004 | 08:19 PM
0554's Avatar
i will answer for blown hatch if thats okay with him. yes you will get a full write up from him. man its sooo cake to do. i recently got my obd-0-obd2 harness from him and had it installed and running in like half hour.
sprjit22
Oct 16, 2006 11:30 PM
92civic_si
16
May 6, 2004 02:50 PM
