replacing fuel pump, do I need to drop the tank?
Old Apr 28, 2004 | 02:26 PM
BIG RICH's Avatar
Default replacing fuel pump, do I need to drop the tank?
I was told that I don't have to drop the tank, but it would be really tight. I'm not really looking forward to doing it, so I'd like the easiest way possible. it's an 89 civic DX hatch. thanks
Old Apr 28, 2004 | 02:57 PM
Harry_Randal's Avatar
Default Re: replacing fuel pump, do I need to drop the tank? (BIG RICH)
Yes
Old Apr 28, 2004 | 03:20 PM
APEX CRX's Avatar
from what I've heard, yes the tank needs to come down. If you end up not having to drop the tank be sure to post up how you did it. I'm sure us EF guys want to know
Old Apr 28, 2004 | 03:26 PM
96-EJ6 B18C's Avatar
Default Re: replacing fuel pump, do I need to drop the tank? (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">from what I've heard, yes the tank needs to come down. If you end up not having to drop the tank be sure to post up how you did it. I'm sure us EF guys want to know</TD></TR></TABLE>
Yes, please do post a how-to...I'll be installing a Walbro 255 soon and that will be very helpful.
Old Apr 28, 2004 | 09:02 PM
Default Re: replacing fuel pump, do I need to drop the tank? (96-EJ6 B18C)
Apparently from what my buddy told me when he did his, there was no way around dropping the tank, or he wasnt able to find one. But like these guys are saying, definately post a how to if you find a way
Old Apr 28, 2004 | 09:09 PM
Reason's Avatar
Out of all the times i changed my fuel pump i had to drop the tank.
Old Apr 28, 2004 | 10:23 PM
dcvt16's Avatar
Default Re: (Reason)
dropping the tank is very easy you just have to tilt it, not drop it can be done in about an hour easy.
Old Apr 28, 2004 | 10:55 PM
mr. carpenter's Avatar
Default Re: (dcvt16)
did it last weekend. undo the three fuel lines on the drivers side. put a jack under the tank. i also suggest using a blanket under the whole gas tank. lower tank with jack and then undo the filler neck and one other hose right there under the rear seat. also undo the fuel level float under the rear seat. i did it without draining about 5 gallons. i got it down by myself but needed help putting it back in. it's not that bad. you just gotta do it. good luck.
Old Apr 29, 2004 | 02:59 AM
FourthGenHatch's Avatar
Default Re:
I'm glad I work at a dealership. When my fuel pump finally takes a crap on me I can put my car on a lift and drain the gas with the gas pump and remove and lower the tank on the "arm".
Old Apr 29, 2004 | 03:26 AM
crxgsr91's Avatar
This guy hit it on the head, except for the hour part took me a little bit longer in a garage with a craftman tool kit.
Old May 20, 2004 | 05:16 AM
ApexiChild's Avatar
Default Re: (crxgsr91)
anyone have pictures of what bolts TO and NOT-TO remove?....
Old May 20, 2004 | 05:28 AM
1's Avatar
Default Re: (ApexiChild)
Make sure you do it when you have very little gas in your tank. Makes life much easier.
Old May 20, 2004 | 07:46 AM
EFSiR's Avatar
I did it last week. The problem I had was with my fuel sender line junction on the driver side where the flex line joins the hard line. It was sooo rusty. I didn't want to take any chances with it so I ended up dropping the tank to a point where i could just take off the top banjo bolt off the fuel pump cover...
While you have the tank out, check the 2-way vavlve located on the driver side of the tank to make sure it's oke dokee.
And finally, cut the return fuel line down to about 8" long. Past 8" from the cover, the line rusts pretty bad. I extended it with 1/4" fuel injected line to the hard line.
HTH
Oh, make sure when you take the tank off, work in an open space. I had my 2 garage doors open and still felt high the next day!!!
Old May 20, 2004 | 09:23 AM
Donkey85's Avatar
Default Re: replacing fuel pump, do I need to drop the tank? (EFSiR)
yes it has to be dropped as said above, but while your there do your self a favor and replace the rubber lines all comming off the tank with new lines and clamps you will be happy u did while u where there instead of redropping the tank at a later date in time to do that just very thing
Old May 20, 2004 | 09:24 AM
alky350's Avatar
u do have to drop the tank on a 89 dx hb, i did about a year ago and it was a bitch doing it myself. you need someone else to help you put the tank back up. i did it myself, but what a bitch using jacks. took maybe a couple of hours
Old May 20, 2004 | 10:47 AM
ricodemus's Avatar
Default Re: replacing fuel pump, do I need to drop the tank? (alky350)
I have to do this soon, but if I remember correctly h-t member "raene" did a write-up on his website.
danno33
Apr 16, 2011 09:23 AM
IHEARTMYHONDA91
Nov 15, 2006 10:27 PM
JeDiMaster
Jul 12, 2006 10:45 PM
Soon_2b_evil
Oct 12, 2004 10:53 AM
hatchback_al
10
Jul 6, 2004 10:36 PM
