Squeaking noise in front suspension
Whats ups guys! I'm new to H-T.
I have this god awful squeaking noise upfront when I roll over bumps. Kinda sounds like a old rickety boat or the frame is tweaking. The car is lowered on H&R's on KYB AGX's. Not to long ago all the bushings were replaced with Prothane ones. I've lubed all major suspension parts one by one and have yet to find where this noise is coming from! Is there grease nipples? Anyone encounter this and maybe have a suggestion as to what it is? Thanks in advance!
Oh yeah the car is a 91 DX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0eKnEe »</TD></TR><TR><TD CLASS="quote">I had the same problem and it ended up comming from the brake dust sheild. I bent it back some and the noise went away.</TD></TR></TABLE>
i have a same setup in an integ, and i sure did bent the dust sheilds when changing axles...what did you do exactly cuss the squeak is driving me crazy...there's another problem too, when i make a hard left, "U"s and stuff there's a scraping noise...did you have that problem too?
something makes a snapping noise like bone braking when I press brakes
I think its the axles on my car I think I dislocated it last time when I pulled it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HmgLauj69 »</TD></TR><TR><TD CLASS="quote">
i have a same setup in an integ, and i sure did bent the dust sheilds when changing axles...what did you do exactly cuss the squeak is driving me crazy...there's another problem too, when i make a hard left, "U"s and stuff there's a scraping noise...did you have that problem too?</TD></TR></TABLE>
Yeah I had that same problem but found out it was the mud flaps rubbing on the ground. Now they don't scrape because they've ground down to the appropriate shape!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mark Surface »</TD></TR><TR><TD CLASS="quote">
i took off my mud flaps long ago, still stomped on what's making that noise
</TD></TR></TABLE>i took off my mud flaps long ago, still stomped on what's making that noise
slateEKsi
15
Aug 10, 2021 04:43 PM
AcCO12D95
Feb 15, 2018 04:59 PM
