Quick question about the red braided line that leads to the charcol canister...
Old Apr 28, 2004 | 02:03 PM
*Boostwerks*'s Avatar
Default Quick question about the red braided line that leads to the charcol canister...
Does it see vaccum? or is it before the TB?
Just need to figure out what to connect it too with my setup.
Old Apr 28, 2004 | 02:23 PM
91civicDXdude's Avatar
it does *not* see vacuum. if you hook it to vacuum, it will make your idle surge. it is simply a vent. if you dont have provisions on your throttle body, then just vent it to air.
Old Apr 28, 2004 | 02:33 PM
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">it does *not* see vacuum. if you hook it to vacuum, it will make your idle surge. it is simply a vent. if you dont have provisions on your throttle body, then just vent it to air.</TD></TR></TABLE>
Werd. Exactly what I needed.
Thanks!
Old Apr 28, 2004 | 03:53 PM
SETI20's Avatar
Do you need to loop it? (closed circuit?)
Plug it up?
Just cut it off?
Old Apr 28, 2004 | 05:22 PM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">Do you need to loop it? (closed circuit?)
Plug it up?
Just cut it off?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">, then just vent it to air.</TD></TR></TABLE>
Reading Owns jOo
Old Apr 29, 2004 | 01:23 AM
SETI20's Avatar
Default Re: (96-EJ6 B18C)
yeah,...ha ha,...and ha.
There are more lines to that canister, my young padwan.
jdmray
Nov 1, 2007 07:02 PM
Ron Burgandy
Jul 19, 2007 02:30 PM
Nisif
Jun 15, 2006 08:48 AM
abnaasefmb
25
Nov 5, 2005 11:35 PM
Luder85
Sep 8, 2005 08:17 AM
