what should i look for when shopping for used cams?
Old Apr 28, 2004 | 12:11 PM
ruthless013's Avatar
Default what should i look for when shopping for used cams?
i've been approached by a buyer of some of my parts for a trade of some used type r cams and cash. i've never dealth with cams (new or used) before, so beyond the obvious (cracked in half, holes in them) where should i look to check the condition? i imagine there are sections of each that may wear, i just don't know where.
thanks in advance.
Old Apr 28, 2004 | 09:23 PM
Default Re: what should i look for when shopping for used cams? (ruthless013)
please help.
Old Apr 28, 2004 | 11:00 PM
NONFLYT's Avatar
I dunno that much baout cams, but a great way to check someones credability is to see if they are a member of Honda-tech and get people to vouch for him.
Basics of cams:
Look for any lobes that are flat. The cam is junk if any lobes are flat.
If the deal is too good to be true then it probably is and you are getting b16 or GSR cams instead of Type R.
Search for Type R cam specs in the Archives i am sure you can find more info
Oh yeah the tips of the cam lobes will be shiny from wear. If the lobe is shiney all the way around THIS IS NOT GOOD. Good luck
Peace
Old Apr 28, 2004 | 11:03 PM
Sack Master's Avatar
Default Re: what should i look for when shopping for used cams? (K20EF)
Time to get out the micrometer. Check for any wear on any of the lobes and the journels. But check all the specs. I don't know the specs for an ITR cam, but they are easy to find.
ek4serge
Mar 21, 2011 01:32 PM
rookshot06
Jul 18, 2008 06:25 AM
killacam20
Apr 13, 2005 09:08 PM
khcivic
Apr 11, 2003 02:06 PM
GSRacer
Apr 4, 2002 02:05 PM
