i have a question that really didnt get answered in "Guide to basic accords" please dont flame
Ok guys this is for my girlfriends car.....her mantence required is lit red now, she told me it was yellow, now its red......i thought it was like anynew car which will tell you that is a good time to go get all your fluids change, right......well yesterday she had her oil changed since i was at work, she showed the receipt and the changed her tranny fluid to since its and auto.....well the lights still on and i want to know what else could require mantentce......i've cheaked all her fluids and they are good to go....so any and all would be helpful....thanks
what year is the car? there should be a reset slot that you can stick a key in and it will change the color back to green on the gauge cluster. check and see if you can see that.
If it's a sixth generation, push in the reset button (same as the trip odometer?) with the car turned off, turn the car to "on" (but don't start it), wait five seconds or so. At that point it will be reset, and will turn back on when she starts the car after 6,000 miles, and will stay solid after 7,500 miles.
It's just a reminder, it has no way of knowing what maintenance you have done to the car.
What is the year and make of the Accord, and how many miles does it have?
More information about the maintenance light, and how to turn it off, will be in her owner's manual, if she has it.
its a 95 and it has 122000 on it wheres the reset butten?
it is right around the little box that is red. it is a black button that any pen would press in.
use a key, push it in, itll go back to green....the hole is right below the CEL light....it goes green, yellow, red.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22edAccord »</TD></TR><TR><TD CLASS="quote">it is right around the little box that is red. it is a black button that any pen would press in.</TD></TR></TABLE>
Conveniently an ignition key fits the slot exactly.
thanks for not flaming guys......ill fix that later tonight......
for the help
for the help
