US and JDM ITR throttle body the same size?
Old Apr 28, 2004 | 10:18 AM
EMO-anthony's Avatar
Default US and JDM ITR throttle body the same size?
Is the US and JDM ITR throttle body the same size?
Old Apr 28, 2004 | 12:42 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: US and JDM ITR throttle body the same size? (THAiGuYDc2)
62 mm, to be exact.
Old Apr 28, 2004 | 05:30 PM
Maximus's Avatar
Default Re: US and JDM ITR throttle body the same size? (SpoonDC2R)
The only difference between the two are the bolts holding the TPS sensor in place. The JDM one uses JDM bolts and the usdm one uses typical phillip head screws.
Old Apr 28, 2004 | 06:23 PM
esponet's Avatar
usdm ones are missing the evap vacuum lines on top next to the map, jdm ones have them. but you could just plug it with a vacuum cap.
Old Apr 28, 2004 | 10:35 PM
Default Re: (esponet)
are GS-R throttle bodies the same size as the ITR ones?
Old Apr 28, 2004 | 10:52 PM
esponet's Avatar
nope, gsr,ls,ctr are the same in size. but itr ones are bigger.
Old Apr 28, 2004 | 11:06 PM
whats the advantage from switching from my GS-R throttle body to a ITR throttle body? I appreciate your response and thanks for not flaming me about it.
Old Apr 28, 2004 | 11:21 PM
esponet's Avatar
bigger and more air flow, but you need to change the manifold, and t/b cable. itr t/b does not have a bolt hole for gsr cable and bracket.
although you could "getho rig" it
Old Apr 28, 2004 | 11:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">bigger and more air flow, but you need to change the manifold, and t/b cable. itr t/b does not have a bolt hole for gsr cable and bracket.
although you could "getho rig" it</TD></TR></TABLE>
I have a Skunk 2 manifold so I think the throttle body should bolt right on to it.
Old Apr 29, 2004 | 05:18 AM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">nope, gsr,ls,ctr are the same in size. but itr ones are bigger.</TD></TR></TABLE>
ctr is same size as ITR from what i have personally seen
Old Apr 29, 2004 | 05:44 AM
EEK's Avatar
EEK
Default Re: US and JDM ITR throttle body the same size? (Maximus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maximus &raquo;</TD></TR><TR><TD CLASS="quote">The only difference between the two are the bolts holding the TPS sensor in place. The JDM one uses JDM bolts and the usdm one uses typical phillip head screws. </TD></TR></TABLE>
i never noticed that before..on my old hatch..i noticed my tps sensor was riveted in though
tallblondkid
Apr 20, 2005 03:15 PM
Dirty GS-R
Sep 5, 2003 02:01 PM
yellowbuffalo
Jun 15, 2003 10:30 AM
JohnnysEG
May 19, 2003 08:57 PM
se93
Jul 9, 2002 03:07 PM
