New Skunk2 Camber kit... No more mods needed?
Old Apr 28, 2004 | 10:02 AM
AssPenny's Avatar
Default New Skunk2 Camber kit... No more mods needed?
Well after getting the wrong camber kit and a bunch of running around, a Skunk2 camber kit arrived today. Well after opening it I noticed something different. Looks like they finaly listened to the consumers and redesigned them:
Old Apr 28, 2004 | 10:06 AM
Chris N's Avatar
Default Re: New Skunk2 Camber kit... No more mods needed? (AssPenny)
Definitely a newer design.....
Old Apr 28, 2004 | 10:08 AM
RTW DC2R's Avatar
Looks interesting, tighten from the bottom it looks like? The plate on the top is probaby a good idea, more friction area to prevent slippage and might help prevent bending if you hit the top of the fender well. I havent had any problems with mine, I have the old version and took the necessary precautions.
Old Apr 28, 2004 | 10:09 AM
.RJ's Avatar
.RJ
Interesting.......
I was planning on buying the comptech pieces...
Old Apr 28, 2004 | 10:15 AM
RTW DC2R's Avatar
I thought about putting an aluminum or steel plate like that on the top of mine, but the ball joint sticks up some and it would take some creativity and tools to make a plate that will work right. That looks like a pretty good design. I still dont like how they make that middle piece on the "slot" so skinny, I think they should beef that up some.
MattD@Stoptech's Avatar
Hopefully the lower mount (w/ balljoint on it) doesn't have any threads in it...
Old Apr 28, 2004 | 10:22 AM
AssPenny's Avatar
Default Re: New Skunk2 Camber kit... No more mods needed? (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">Hopefully the lower mount (w/ balljoint on it) doesn't have any threads in it...</TD></TR></TABLE>
No it doesn't. And if it did, they need to fire the monkey that designed it
Old Apr 28, 2004 | 10:27 AM
cre18's Avatar
looks good , wonder if they are taking trade ins
Old Apr 28, 2004 | 10:28 AM
Chris N's Avatar
I'd still rough up the red paint on the rails of the arm with a dremel.
Old Apr 28, 2004 | 10:39 AM
BolivianDc2's Avatar
Default Re: New Skunk2 Camber kit... No more mods needed? (Chris N)
is it a total of 3 pieces now? or is the balljoint all one piece?
Old Apr 28, 2004 | 10:40 AM
juicy.fn's Avatar
asspenty pmed u
Old Apr 28, 2004 | 10:42 AM
lanceh's Avatar
25 Year Member
Default Re: New Skunk2 Camber kit... No more mods needed? (BolivianDc2)
and from the looks of it the arm is exactly the same. so us previous gen owners can replace with the new balljoint setup.
Old Apr 28, 2004 | 10:56 AM
AssPenny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 &raquo;</TD></TR><TR><TD CLASS="quote">is it a total of 3 pieces now? or is the balljoint all one piece?</TD></TR></TABLE>
It is a total of 3 pieces. The arm, the ball joint and the top plate. The ball joint and the top plate are held together by 4 allen head bults with lock washers.
Old Apr 28, 2004 | 10:59 AM
Default Re: New Skunk2 Camber kit... No more mods needed? (lanceh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanceh &raquo;</TD></TR><TR><TD CLASS="quote">and from the looks of it the arm is exactly the same. so us previous gen owners can replace with the new balljoint setup.</TD></TR></TABLE>
and the fuggers must have just done it...cause my ball joint replacement arms are not of this design....
BLAH!
Old Apr 28, 2004 | 11:20 AM
Chris N's Avatar
Old Apr 28, 2004 | 11:23 AM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">
It is a total of 3 pieces. The arm, the ball joint and the top plate. The ball joint and the top plate are held together by 4 allen head bults with lock washers.</TD></TR></TABLE>
ALLEN HEADS, yuck More bolts to strip I hate allan headed anything...for some reason every allen headed item I have ever used manages to strip out after a few uses.
Old Apr 28, 2004 | 11:32 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Besides slipping, the old design had clearance issue with the shock tower when car is lowered passed a certain point.
Now it looks like the slipping problem is solved (still needs to be proven), but would that extra plate on top further decrease the clearance inside the shock tower?
Old Apr 28, 2004 | 11:47 AM
Default Re: New Skunk2 Camber kit... No more mods needed? (Austin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">
ALLEN HEADS, yuck More bolts to strip I hate allan headed anything...for some reason every allen headed item I have ever used manages to strip out after a few uses.</TD></TR></TABLE>
Could be j00r allen wrenches....
Old Apr 28, 2004 | 11:53 AM
AssPenny's Avatar
Default Re: (jdm wannabe)
BTW, these were from http://www.wiredspeed.com if anybody cares.
Old Apr 28, 2004 | 12:21 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">BTW, these were from http://www.wiredspeed.com if anybody cares.</TD></TR></TABLE>
no, we don't care, but Lindsay is coming to Orlando this weekend.
Old Apr 28, 2004 | 01:03 PM
Dave-ROR's Avatar
Default Re: (RealTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">
no, we don't care, but Lindsay is coming to Orlando this weekend. </TD></TR></TABLE>
So? we were with lindsay many hours this past weekend. Hooray for you seeing her a week later!
Old Apr 28, 2004 | 03:41 PM
92civic_si's Avatar
nice!! the new camber kit looks hella nice..i hate the old design coz i got the old one..went thru helle problemsssssssssssss..blah..anyhoo bump!
Old Apr 28, 2004 | 03:59 PM
Wai's Avatar
Wai
Default Re: (Dave-ROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">So? we were with lindsay many hours this past weekend. Hooray for you seeing her a week later!
Marc gets sloppy second......
Old Apr 28, 2004 | 04:31 PM
Rob :190:'s Avatar
Default Re: (Wai)
i tot you were selling the car craigers?
Old Apr 28, 2004 | 07:16 PM
stumpyf4's Avatar
Default Re: (Wai)
Ball joint boots are still too small, replace those with some OEM boots. Also makes it a pain to adjust camber on the rack... need to remove the tire to get to those bolts.
I encountered a nasty creak as well, arms were touching the frame at some suspension angles.... scroll down below.
https://honda-tech.com/zerothread?id=838684
