Hydro tranny with cable motor?
Old Apr 28, 2004 | 08:05 AM
mugenracer's Avatar
Default Hydro tranny with cable motor?
I picked up a JDM B16a from an XSi with less than 45k miles on it for $600 and so couldnt turn it down and i also got the Y1 cable tranny with it plus harness/ecu/drives etc, its going into an EG4 shell along with the XSi harness/ECU etc etc. The EG4 originally had a hydro tranny and so has all the ancillaries for a hydro tranny. I have a Y21 tranny earmarked but need to know if it will bolt to the B16 which originally ran a cable tranny, or would it be easier to convert the whole lot to cable tranny and what is involved? I have spent ages searching and from what i found, a hydro tranny will bolt to the B16a without problem (am i right?) but are there any other problems associated with a conversion like that?
Old Apr 28, 2004 | 08:25 AM
mmuller's Avatar
Mad Scientist
Default Re: Hydro tranny with cable motor? (mugenracer)
yeah, it will bolt just fine, make sure you get a clutch for a hydro tranny tough
Old Apr 28, 2004 | 09:14 AM
mugenracer's Avatar
Default Re: Hydro tranny with cable motor? (mmuller)
Thanks, can you just clarify what you said, do i fit a hydro clutch to the cable tranny and use it or get the Y21 hydro and fit a hydro clutch to it?
Old Apr 28, 2004 | 10:49 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, can you just clarify what you said, do i fit a hydro clutch to the cable tranny and use it or get the Y21 hydro and fit a hydro clutch to it?</TD></TR></TABLE>
well, cable tranny's have a smaller spline than their hydro counterpart, so if you want to use a hydro tranny you need a hydro cluthch disc; if you want cable you need a clutch disc for a cable tranny.
also, if you use a cable tranny in a hydro car, you need to buy a hydro to cable conversion.
if i were you i would just use a hydro tranny since they are also better than cable
crazyguy
Jul 31, 2007 05:59 AM
flipldls
Jun 24, 2007 08:34 PM
Walterronny
May 27, 2006 04:12 PM
jdmCivic925
Sep 23, 2003 10:02 PM
