another (2) questions about a/c bracket...
im swaping a b16 in my 93 delsol si and you guys and everyone else told me that i need the p54 a/c bracket to do the swap. do i actually need it if i decide not to have a/c at all, b/c my a/c is goin bad anyway? wouldnt i just need a shorter belt that wouldnt connect to the a/c? i appreciate your help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cakemommy »</TD></TR><TR><TD CLASS="quote">im swaping a b16 in my 93 delsol si and you guys and everyone else told me that i need the p54 a/c bracket to do the swap. do i actually need it if i decide not to have a/c at all, b/c my a/c is goin bad anyway? wouldnt i just need a shorter belt that wouldnt connect to the a/c? i appreciate your help!
yes you need the p54 bracket so that the stock civic a/c compressor bolts up to the bracket and to then to the motor correctly.. no you dont need and you can use the stock b16 a/c mount as a tourqe mount if you even use them and i would suggest using both tourqe mounts.. and shortening the belt has nothing to do with it, althought it may be needed, the p54 bracket allows the compressor to be bolted on saftley
</TD></TR></TABLE>yes you need the p54 bracket so that the stock civic a/c compressor bolts up to the bracket and to then to the motor correctly.. no you dont need and you can use the stock b16 a/c mount as a tourqe mount if you even use them and i would suggest using both tourqe mounts.. and shortening the belt has nothing to do with it, althought it may be needed, the p54 bracket allows the compressor to be bolted on saftley
redman223
Jun 14, 2007 09:15 AM
