a6 tranny on z6 motor
cool. as far as the swap goes, will i need additional harnesses besides what is given with the motor and ecu.
it's a complete swap with motor mounts and tranny. i'll use the tranny on my ex
Did you get the ecu as well? If so, then you should get an OBD0 to OBD1 wiring harness conversion (IM Blown90Hatch). He can also answer any questions you have about wiring using his harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSOHChatch »</TD></TR><TR><TD CLASS="quote">is this the same harness they sell at http://www.jdmshit.com ?</TD></TR></TABLE>
It is the same type of harness, but not the same exact ones.
use an auto tranny ps9 ecu, buy some chips, look up the 1-wire vtec stuff, set all that up. save yourself the money on the obd1 ecu and harness swap(s).
then use turboedit or some obd0 editor to tune the maps for the Z6 and VTEC
that is a good idea, but i really don't know how to do this and i want to make the swap go as smooth as possible. but do i need to use a 90 and up clutch set-up though?
