non vtec b20 header hang low????
Old Apr 27, 2004 | 09:03 PM
AllMotorMark's Avatar
Default non vtec b20 with itr header hang low????
does a stock b20 sit lower in a car compared to a 1.8L gsr?? if somone where to put a header from an itr or gsr on to the b20 would it sit closer to the ground compared to the itr/gsr?
Modified by AllMotorMark at 8:35 AM 4/28/2004
Old Apr 28, 2004 | 04:34 AM
Default Re: non vtec b20 header hang low???? (AllMotorMark)
ttt
Old Apr 28, 2004 | 04:49 AM
lsvtec101's Avatar
clerance should be good using a itr
Old Apr 28, 2004 | 01:15 PM
Default Re: non vtec b20 header hang low???? (aemcivic_02917)
but will it hang lower then or be the same as the itr motor with the same header
Old Apr 28, 2004 | 03:16 PM
lsvtec101's Avatar
dont know never had 2 cars side by side, but on my b20z it cleared nicely
Old Apr 28, 2004 | 05:24 PM
white_n_slow's Avatar
clearance should be roughly equal to that of a b18b... externally, its the same size as the b20.
Old Apr 28, 2004 | 05:49 PM
Default Re: non vtec b20 header hang low???? (white_n_slow)
ya but will a header that is made for a itr sit lower or higher to the ground, when used with a b20
Tank Martinson
Feb 18, 2016 02:30 PM
Tank Martinson
Feb 17, 2016 03:17 PM
B18ek
111
May 27, 2009 09:46 AM
No-Gi
Sep 24, 2002 01:11 PM
