Urgent Question re: ITR shocks/springs in GSR
Old Nov 1, 2001 | 11:18 AM
miketegra's Avatar
Default Urgent Question re: ITR shocks/springs in GSR
I have ITR LCA's and ITR shocks and springs for my GSR, and I am going to install them this weekend.
Can I re-use all of the GSR bolts and mounting hardware, or do I need ITR stuff, or what?
Is it time for a trip to the dealership, or will my GSR nuts and bolts work?
Thanks !
Old Nov 1, 2001 | 11:41 AM
JL 74's Avatar
Default Re: Urgent Question re: ITR shocks/springs in GSR (miketegra)
I wish I can help you. I am pondering this myself. Let me know how it went and post it here.
Old Nov 1, 2001 | 01:43 PM
stick's Avatar
everything will swap over but may need longer bolts for ITR LCA's
great choice BTW for susp
Old Nov 1, 2001 | 03:19 PM
Seedc2's Avatar
Default Re: Urgent Question re: ITR shocks/springs in GSR (stick)
a quick question..
how much of a difference is there between the ITR shocks, springs over the GSR?
Well one thing is I know that the ITR is made lower... but not much..
Old Nov 1, 2001 | 03:26 PM
FSTASNTZ's Avatar
If you do a search you may find the spring rates of the ITR springs and the GS-R springs. I cannot find my notes. I do think the rear ITR springs were 166 lbs progressive...
Jason
Old Nov 1, 2001 | 04:23 PM
Nighthawk GS-R's Avatar
New User
Default Re: Urgent Question re: ITR shocks/springs in GSR (FSTASNTZ)
the rear springs rate are something like 266-390 progressive i believe. I just did this set up myself on my gs-r (courtesy of STICK) My LCA's came with new bolts but im pretty sure the stock ones will fit?? This setup is great guys, i can't say it enough. this is the best setup ive ever had. honda OEM is the BEST.
Old Nov 1, 2001 | 06:48 PM
stick's Avatar
Default Re: Urgent Question re: ITR shocks/springs in GSR (Nighthawk GS-R)
spirng rates:
GSR: 212 lb/in front; 117 lb/in rear-linear
ITR: 246 lb/in front; 140-246 lb/in rear-progressive
also ITR shocks are more stiffer and thicker hence the use of ITR LCA's (JDM stuff)
[Modified by stick, 7:49 PM 11/1/2001]
92redhatch
Suspension & Brakes
Feb 11, 2010 01:41 PM
vidanator
Suspension & Brakes
May 17, 2005 04:06 AM
Projected
Nov 10, 2002 04:09 PM
miketegra
Nov 1, 2001 11:28 AM
