ITR oil change....how long does car need to idle afterwards?
Old Apr 27, 2004 | 07:29 PM
HUBB's Avatar
Default ITR oil change....how long does car need to idle afterwards?
changed my oil today and let it idle for about 2 minutes before driving off.....is that alright or should i let it idle until completly warm next time...just curious to know if it even matters..btw..2000 JDM ITR...castrol syntec 10w-30...no harm done hopefully.....i just figured to let it cylce through like any other warm up and run her....thanx
Old Apr 27, 2004 | 07:35 PM
B2FiNiTY's Avatar
Default Re: ITR oil change....how long does car need to idle afterwards? (HUBB)
Doesn't really matter. The purpose of letting it idle is to use that time to check for leaks and make sure everything is kosher before driving off.
Old Apr 27, 2004 | 08:15 PM
HUBB's Avatar
Default Re: ITR oil change....how long does car need to idle afterwards? (B2FiNiTY)
w3rd ---thanx
Old Apr 27, 2004 | 08:27 PM
Justin Klemgold's Avatar
Default Re: ITR oil change....how long does car need to idle afterwards? (PHXITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHXITR &raquo;</TD></TR><TR><TD CLASS="quote">That wouldn't hurt the engine at all. The oil you put in your car, unless it was in the frigerator, is room temp. Think about when you start your car cold in the morn....that is worse. When you drain oil out of an engine there is still about 1-2 qts left in the block so lubrication immediatelty after an oil change is no problem. Dont worry....no harm done to your B18C5! Doesn't hurt to warm the car up though if it has been sitting awhile.</TD></TR></TABLE>
Eh? 1-2 quarts left in the block? That doesn't sound right....
Old Apr 27, 2004 | 08:34 PM
HUBB's Avatar
Default Re: ITR oil change....how long does car need to idle afterwards? (Justin Klemgold)
1/2 quart tops
Old Apr 27, 2004 | 11:35 PM
MiraiZ's Avatar
after the oil light goes out and you've made sure that there's no leaks
Old Apr 28, 2004 | 05:46 AM
IN VTEC's Avatar
After filling the oil, I always let it idle for a few seconds after the light goes out, shut it off, and recheck the oil level.
Old Apr 28, 2004 | 05:56 AM
sackdz's Avatar
do i have to take my subs out my hatch to chek the oil cuz they heavy and i thaught maybe it would tilt my ride and make the stick dip not reading right.
Old Apr 28, 2004 | 06:15 AM
Default Re: ITR oil change....how long does car need to idle afterwards? (sackdz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">do i have to take my subs out my hatch to chek the oil cuz they heavy and i thaught maybe it would tilt my ride and make the stick dip not reading right.</TD></TR></TABLE>
Are you being serious?
Old Apr 28, 2004 | 06:30 AM
IN VTEC's Avatar
About as serious as cold macaroni and cheese.
Old Apr 28, 2004 | 06:31 AM
sackdz's Avatar
thats just what my boy told me i dunno if its true but hes got a civic si with ls vtec swap just wondering
Old Apr 28, 2004 | 06:32 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">thats just what my boy told me i dunno if its true but hes got a civic si with ls vtec swap just wondering</TD></TR></TABLE>
sackdz gone stunna.. hilarious..
Old Apr 28, 2004 | 06:33 AM
lanceh's Avatar
25 Year Member
bored today ed?
Old Apr 28, 2004 | 06:41 AM
Chris N's Avatar
Holla, mah bois told me dat same chit y0!
And there ain't no 1-2 quarts of oil left in the block after draining the oil, what the f0k!!!?
hatchedeg
Jun 17, 2006 05:00 AM
JDM_SOHC
Dec 1, 2005 10:13 AM
Acura EL
Nov 24, 2004 03:11 PM
HUBB
Apr 28, 2004 06:41 AM
freeplay
Sep 13, 2003 02:16 PM
