Oil residues in the radiador system!
I have a Honda Accord 1999 and a problem of my car is this mixing oil for the cooling system (radiator, reserve coolant, water pump, etc.) And nonencounter through where is happening? The temperature of the car is good, not high temperature. Please help me , Thanks
I have a Honda Accord 1999 and the problem that has my car is that this mixing oil for the cooling system (radiator, reserve coolant, water pump, etc.) And nonencounter through where is happening? The temperature of the car is good, not high temperature but the coolant is contains oil residues and don't know to which is the problem. You help me with this problem.
The headgasket is the gasket in the _________? I change the gasket in the camara valve(gasket with metal part) and the car is working good ( 3 weeks) ; and now the problem is back.
Thanks you
#6 is the cylinder head gasket.
Eduardo's asking whether it has an automatic or manual transmission. Automatic transmissions can have an oil cooler built into the radiator, maybe that's where the oil is getting into the coolant??
Where are you located?? USA Accord is a completely different car than what most of Europe & Asia have.
I changed this gasket with the original head gasket and to rectify the cover valve, but the screws were not new, we used such. This problem me this returning crazy,
help me alternative for to solve this problem. Send me diagram for other option.
My email is lursan2125@aol.com . Thanks
da1lydr1ver
13
Dec 6, 2006 06:04 PM
SPORT INJECTION
Aug 25, 2003 12:15 PM
