S2K antenna on a 5th gen Accord help
Old Apr 27, 2004 | 04:59 PM
jwogen1's Avatar
Default S2K antenna on a 5th gen Accord help
Well I have searched without any solid finds or feedback....so I am just curious as to any help or anything anyone ran into while performing this conversion. It seems pretty simple and my stock one is shot--so i figured what the hell. I found one thread for the 4th gen which is pretty much the same, so it will help.
I am curious as to what to do with the wire running into the collar/tube on the antenna. I only have the actual s2k antenna mast. Anyways any help would be cool. Thanks.
Old Apr 27, 2004 | 05:48 PM
jwogen1's Avatar
Default Re: S2K antenna on a 5th gen Accord help (jwogen1)
the antenna wire that is running into the motor assembly and/or base of the mast SearchBeforeYouPost.
Old Apr 27, 2004 | 05:59 PM
SearchBeforeUPost!'s Avatar
the part on the left, the male connector, which comes in the kit or you have to make it, is bolted to the antenna base. It plugs into the female connector, which is already in your car: that black wire hanging on the white antenna base.
Old Apr 27, 2004 | 06:24 PM
jwogen1's Avatar
Default Re: S2K antenna on a 5th gen Accord help (SearchBeforeUPost!)
cool cool, im followin you now. coaxle tv cable and male antenna piece from radio shack correct. then the the yellow wire cap with connector for antenna base.
RD6
Jun 8, 2009 07:25 PM
pfork
Jan 17, 2008 09:39 AM
Civiclx
Jun 9, 2003 10:35 PM
fastaccord94lx
May 12, 2003 03:52 PM
