multi port injection swap
Old Apr 27, 2004 | 03:48 PM
91d15hatch's Avatar
Default multi port injection swap
i was wondering if i could take a multi-port intake manifold and put it on my d15 with dual point injection. it seems to me that i would have to update my ecu. but maybe not. help me out if you guys know anything.
Old Apr 27, 2004 | 03:49 PM
ijjz's Avatar
Default Re: multi port injection swap (92horsepower)
Search for MPFI in CRX/EF forums only.
Old Apr 27, 2004 | 05:20 PM
ham's Avatar
ham
its alot more work than that bro... . running injector wires and repinning the ECU.
Old Apr 27, 2004 | 06:47 PM
Honda101's Avatar
Me personally I think the multi point swap is not worth it, unless you had a 1989-91 Honda Civic Si doner car. You will need a different head, new ECU, distributor,
Sorry, that would convert that D15 to an Si, which would be better in my opinion, but anyways . . .
For the money just swap out your motor for a B16 or something better than the D15.
Old Apr 27, 2004 | 06:53 PM
SOHC Gord's Avatar
free bump
Old Apr 27, 2004 | 06:59 PM
tilt's Avatar
Default Re: multi port injection swap (Honda101)
you need a mpfi intake manifold, not a new head.
and to answer the posters question, yes you need a new ecu. crx si pm6 works fine.
this is the best writeup afaik:
http://www.fourthgenhatch.com/mpfi.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda101 &raquo;</TD></TR><TR><TD CLASS="quote"> Me personally I think the multi point swap is not worth it, unless you had a 1989-91 Honda Civic Si doner car. You will need a different head, new ECU, distributor,
For the money just swap out your motor for a B16 or something better than the D15. </TD></TR></TABLE>
Old Apr 28, 2004 | 04:19 AM
8psiover's Avatar
Default Re: multi port injection swap (tilt)
put a d-series vtec head on it, that will make it more worth while, let me know if u want more information about it
Old Apr 28, 2004 | 07:26 AM
4drEF's Avatar
Keyboard Humorist
You still need to do the MPFI conversion to run the B16 motor.
For about $100/$150 (you can probably find it for less if you search around) you can have a MPFI swap. That $100/$150 won't even come close to getting a set of mounts for the B16.
Old Apr 28, 2004 | 10:18 AM
mr. carpenter's Avatar
Default Re: multi port injection swap (4drEF)
yeah, multi point swaps are stupid. don't waste you're time. nobody does that around here. seriouslah, it's not that hard but does take a little research and some work on the car. research it on here through the search as mentioned before and take your time you can find all the parts you need from people here. hell, i've an extra manifold and will have an ecu when i get mine from zdyne. pm me if you're interested in buying them. IT DOES MAKE QUITE A DIFFERENCE.
Modified by mr. carpenter at 8:18 PM 4/28/2004
Old Apr 28, 2004 | 10:40 AM
sodacan33's Avatar
Default Re: multi port injection swap (mr. carpenter)
i would not say there not worth it , that is if you get your si head an dizzy ,manifold for free or like 50$ thats what i did an its fine for a everyday driver nothin fast. But if would be better to just save up for a better motor. But look on the bright side if you do the mpfi swap you will have the harness an ecu ready for another swap
Old Apr 28, 2004 | 10:44 AM
green91's Avatar
the mpfi conversion is worth ever dollar you put into it. dont listen to these ignorant people who probably haven't even done mpfi!
Old Apr 28, 2004 | 10:47 AM
redzcstandardhatch's Avatar
something different
Default Re: (green91)
yup....it makes a d15 scream, especially if you do all the bolt on's at the same time like we did for a buddy of ours a few weeks ago. si tranny, Lightweight flywheel, clutch, intake, header, and exhaust and MPFI swap. NIGHT AND DAY DIFFERENCE. its probably a low 15 second car now. easily.
kyle48_2007
20
Apr 29, 2013 04:31 PM
zeb1117
Feb 23, 2010 08:10 PM
sublimeh215
Mar 12, 2009 10:55 AM
joesefcivic
Jul 15, 2003 04:03 PM
JStone2775
Aug 15, 2002 12:39 AM
