need advice on how to install a slave cylinder
how is everyone doing. well the other day i noticed that my clutch went all the way to the floor and had no pressure. i looked up the hood and the slave cylinder was leaking all the fluid around the black rubber piece. the car is a 1990 accord ex 4dr. could someone please send me some instructions to do this. thank you
I'm thinking you would first remove the clutch line from the slave cylinder then remove the two screws that hold the slave cylinder to the tranny and it should come off. It's pretty simple.
so pretty much i just have to take those 2 screws off and the one line right there and then the other one will plug right back in.. thats great but one more thing where is the input so i can put more clutch fluid in and what kind should i get. thanks alot man you are very helpful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nubehonda »</TD></TR><TR><TD CLASS="quote">so pretty much i just have to take those 2 screws off and the one line right there and then the other one will plug right back in.. thats great but one more thing where is the input so i can put more clutch fluid in and what kind should i get. thanks alot man you are very helpful.
Use regular old brake fluid, DOT3. You will have to bleed the air out when you get the new slave cylinder installed.
</TD></TR></TABLE>Use regular old brake fluid, DOT3. You will have to bleed the air out when you get the new slave cylinder installed.
I can not seem to find my slave cylinder. I know I have to replace the master and someone told me I should replace the slave as well. i have a 94 accord ex. If someone just describe where it's at or even take a picture that would be great.
Nickhead
May 20, 2011 03:20 PM
