Wheel bearings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">a 20 ton press
good thing i have one
</TD></TR></TABLE>good thing i have one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">
everybody has one of those in their backyards
</TD></TR></TABLE>everybody has one of those in their backyards
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot »</TD></TR><TR><TD CLASS="quote">Could you not use your hand ??!
Hellboy?
</TD></TR></TABLE>Hellboy?
https://honda-tech.com/zerothread?id=720159
edit:
me - st00pid. front does not = rear.
Modified by Willard at 10:30 PM 4/27/2004
edit:
Hellboy?
That's a huge gun that he has. That would probably work in place of a press too.
Hellboy?
</TD></TR></TABLE>That's a huge gun that he has. That would probably work in place of a press too.
Sealed on the rear, ie a hub itself, front have to replace the bearing, ie press into hub.
Very easy so long as your driveshaft hasn't seized on to the bearing, otherwise you have to take the driveshaft out of the tranny,. some how balance it on the press with the knuckle and press it out, I know because it happened to me
Good luck, be careful though, I replaced my passenger front bearing and by three months it had gone again
It was a Timken if it helps which is a reputable company however.
Edit--Just read for the rear, get a helms if your stuck, shouldn't though.
It was a Timken if it helps which is a reputable company however.Edit--Just read for the rear, get a helms if your stuck, shouldn't though.
philibuster
Oct 21, 2005 05:53 AM
