90-91 Hatch Si seats in a 90 CRX DX???
does anyone know if the seats from a 90-91 hatch will fit into a 90 crx dx? can i swap the rails? anyway to do this? someone please help me! thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHatchSOHC »</TD></TR><TR><TD CLASS="quote">You dont need to swap them. itll fit directly</TD></TR></TABLE>
You're full of crap.
You need to modify the rails. NOT A DIRECT SWAP AT ALL!
I actually had to weld my CRX rails onto the Civic seats.
they are are the same, i put si seats in my dx without any mods, i gess that guys seats that he had to weld wer from the wrong year, 88-89 seats teh seat railsare closer together, while the 90-91 seats rails are wider apart, those seats will fit in your car without mods
I have
2 Seats from a 1990 Civic Si. I have 2 Seats from a 1991 CRX DX.
<FONT SIZE="5">THEY ARE NOT ******* INTERCHANGEABLE</FONT> you cannot put Civic seats in the CRX nor can you put CRX Seats in the Civic.
<FONT SIZE="5">Different mounting points entirely!</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I have also heard that you cannot swap civic si seats into a crx without modifying the rails. </TD></TR></TABLE>
Finally!! Another guy that knows his stuff.
As for you non-believers, I will take pics of the horror that is the alignment/spotweld process if you all would wish. But whatever you guys wanna do. Waste all of your money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede »</TD></TR><TR><TD CLASS="quote">
LOL, I know how it can be sometimes.
</TD></TR></TABLE>LOL, I know how it can be sometimes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91siredrex »</TD></TR><TR><TD CLASS="quote">well i dont believe anything with seats cause i have 89 crx si seats in my 91 crx. so i dont know.</TD></TR></TABLE>
crx seats in a crx is a different story... were talking Civic Si Hatch seats in a CRX....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegasRex90 »</TD></TR><TR><TD CLASS="quote">
crx seats in a crx is a different story... were talking Civic Si Hatch seats in a CRX.... </TD></TR></TABLE>
LOL... OWNED!!!
Sorry, I thought you could use some encouragement.
LOL... OWNED!!!
Guest
Posts: n/a
from post https://honda-tech.com/zerothread?id=166253 crx seat in a dx hatch same thing our asking just the other way around. Same procedure will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF'n Fast »</TD></TR><TR><TD CLASS="quote">They will fit, but the bolt pattern is slightly different.
88, 89, and 90-91 had different bolt patterns on the seats. However, you should be able to modify the seat brackets to make them fit.
Or...if you want to put the time into it, you could swap the bottom pans from the seats...but I hear it's very labor intensive.
Measure where the bolts go for your seats and compare them with the 91 seats, they should be slightly different...but very doable. Good luck!</TD></TR></TABLE>
my 2¢
my 2¢
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjaMONKEY »</TD></TR><TR><TD CLASS="quote">you can put your rails and bucket (lower part of the seat thats metal) from your crx to make it fit, at least from what I know off hand.</TD></TR></TABLE>
I tried putting CRX Si seats into my 88 hatch doing this. I failed miserably. The seatpan is very different.
I put 91 Si Seats into my 89 DX.. It took about 2 hours and all I did was go over to the hardware store. Get some longer bolts and nuts and washers. Had to grind the Rails down a little to make em fit snug but wasn't a huge ordeal. Re-Drilled the Holes and Voila they went in like Fylnn..
Here is the Pics of the seats.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarAudiophile »</TD></TR><TR><TD CLASS="quote">I put 91 Si Seats into my 89 DX.. It took about 2 hours and all I did was go over to the hardware store. Get some longer bolts and nuts and washers. Had to grind the Rails down a little to make em fit snug but wasn't a huge ordeal. Re-Drilled the Holes and Voila they went in like Fylnn..
So you put 91 Civic si seats into an 89 Civic dx?
CRX MASE
12
Jan 17, 2007 10:24 PM
