APEXi V-AFC tune help
Hey, I've got a '91 CRX VTEC with some adverage mods were 1 of the includes the APEXi V-AFC.
My problem is that i live in Portugal and in here, there aint any1 that can tune the V-AFC. Hell, there are very few ppl that actually know how to work the basics of it.
So im asking here for some help/guidelines/how-to/whatever on how to tune up my car or any other Honda. We (me and some friends) have access to dynos but dont have a idea on what to do atm to tune it up... Random testing is kinda out of question since we cant afford for all the big f*ck-ups we do, so any help that can help us improve our knowladge in a safe way is greatly apretiated.
thks
thks
k ill see what i can explain
when u go to settings, on the first 2 options u can fix the air fuel
when it is on 0% means is still running the same maps as on the ECU
when u take or give % depending on RPMS it will increase or decrease the duty cycles of the injectors based on %.... % of fuel being injected ( the injector flow in cc)
this maps are not linear
means they dont really have to go from _1% to _10% gradually
u need a air fuel guage and or wideband on a dyno to tell u where u need the fuel corrected.
do a beasline run on dyno with air fuel to look at it
then based on the air fuel u can tune ( 13.5 air guel for N/A and 12-12.5 for turbo)
make changes on the respective rpm points depending how the air fuel looks to make sure u can get the most consisntant air fuel line to keep it on the 13's or whatever
always start with a big change on the % when u wanna make corrections...
start by changing around 6-9% at a time, and from there if u went too far and take away some... that way u can get it tuned
as far as VTEC engagement... make vtec kick at 8k rpms... run the engine, then turn the VTEC to 2k rpms and run it... match both dyno runs and whenever those 2 power curve meets, u want vtec to be on that spot
