intalling tein basic coilover on honda accord 97?
Old Apr 27, 2004 | 09:25 AM
icet's Avatar
Default intalling tein basic coilover on honda accord 97?
hi guys,,,,,
how hard is it to install tein basic coilover on honda accord 97?
can it be done at home?
if any1 have like pictures or instruction to give, i am really appreciates your help.
thanks in advance...
icet....
Old Apr 27, 2004 | 09:44 AM
.bagged's Avatar
Default Re: intalling tein basic coilover on honda accord 97? (icet)
As long as you understand the basic concept of righty tighty lefty loosey you should be ok.
Edit: you might want to rent a spring compressor just to be safe.
Old Apr 27, 2004 | 09:47 AM
P!cKl3$'s Avatar
Default Re: intalling tein basic coilover on honda accord 97? (baGged93aCcord)
All this information and more can be answered here at: http://www.accordinglydone.com/tech/tech.php?ID=71
This website has a lot of technical articles related to DIY's for your accord. Good Luck on your install
This also has to be one of the best write ups I have seen for a new suspension install.
Old Apr 27, 2004 | 10:03 AM
icet's Avatar
Default Re: intalling tein basic coilover on honda accord 97? (P!cKl3$)
thanks for the info guys...
but wondering y do i still the spring compressor if i have a full coilover.
is it just take out the old one and put the new coilover in?
by the way those pics are weally helpful...
thank you...
icet
Old Apr 27, 2004 | 10:30 AM
Twidge's Avatar
you might have to be careful about the rear shocks. where the strut meets the control arm, you would have to heat that bolt up because of the bolt is an autolocking bolt with grooves in it. rust builds up in there so that the bolt doesn't move. so you might need a torch to heat the rust and loosen up the bolt
Old Apr 27, 2004 | 10:58 AM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icet &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info guys...
thank you...
icet</TD></TR></TABLE>
you have to reuse your OEM upper mount.
Old Apr 27, 2004 | 11:15 AM
icet's Avatar
thnks for all the HELPS....
icet
JDMonster3790
Feb 12, 2009 02:56 PM
GreedyAzn
Mar 29, 2007 10:06 PM
stratijikal
Suspension & Brakes
Jul 14, 2006 10:34 PM
