B18C+Place Racing Mounts+Lowered Hatch=Crank pulley rubbing tie rod! HELP
Old Apr 27, 2004 | 06:49 AM
Maddhatcher's Avatar
Default B18C+Place Racing Mounts+Lowered Hatch=Crank pulley rubbing tie rod! HELP
I have a gsr swap into a 90 hatch, and everything was fine until I swapped out my skunk2 springs for koni yellows and GC's. In doing so I dropped it a little more and now the stock crank pulley rubs the tie rod when the shock is compressed when driving up steep driveways or slight grinding during normal driving. CTR pulley is on the way, which should solve the problem. Just wondering if any of you have had this issue. Mounts are place racing and are excellent.
___________________LUKE................Thanks for any feedback.
Old Apr 27, 2004 | 07:37 AM
spaceman's Avatar
Default Re: B18C+Place Racing Mounts+Lowered Hatch=Crank pulley rubbing tie rod! HELP (Maddhatcher)
that new pulley is alternator only correct?..if so then you should be ok
Old Apr 27, 2004 | 08:08 AM
Default Re: B18C+Place Racing Mounts+Lowered Hatch=Crank pulley rubbing tie rod! HELP (spaceman)
yes it is. Yea that should fix the problem because only the ac and powersteering are hitting.
Old Apr 27, 2004 | 08:12 AM
EL Vap133's Avatar
When I had Place Racing mounts, I didn't have that problem. Maybe your ride was lower than mine?
92civiceg9gsr
13
Aug 6, 2011 05:13 PM
whiteguyndahood
Dec 7, 2005 10:33 AM
SRACHAD
Oct 31, 2005 05:15 AM
b18_crx
19
May 17, 2005 11:48 AM
Ri5e
Feb 23, 2002 09:37 PM
