Problem with engine mount :0(
Hi,
I'm Emil from Slovenia,EUROPE and
I'm trying to swap B16A2 in my 90' civic HB
I bought the HASport kit first the one for cable clutch and then the mount for
hydro tranny, cause I just couldn't get any clutch cables tranny for B16A in whole Europe :0( I was forced to buy a hydro one...
So now here is the thing when we tried to swap the engine in we came to this problem that the rear engine mount and right engine mount didn't fit on my hasport mount kit...I didn't know that the mounts on the engine B16A and the mounts on the engine B16A2 are different, so what we wanted to do is widden the holes on engine mount from hasport that did work but now it seems to be problem that the engine is seatting to low on right side and the rear tranny mount don't fit either on my hasport engine mount...
Did anyone had that problem and what is the soultion to solve this problem...
Oh and I can't get those engine mounts in Europe so I'll have to buy ones from the USA, where is The best place to get them very very quick cause I'm kinda in a hurrry...
And one more question will the axles from 92' VTI civic fit to my swap or that won't work either....Keep in mind that I did hydro conv.
Thanks for all the answers
CYA
P.S.:
And if I didn't explain that right here is how it should look and what I need
ENGINE ------- ENGINE MOUNT(BLACK) --------HASPORT MOUNT ------CHASIS
CYA
P.S.:
my bet is that the European Civic/crx's came w/ the JDM rear cross member (because some civics there came w/ b16 from the factory).
Go to a honda dear and get a 90 Civic VTi rear mount. It might not work so make sure you can return it if it doesnt fit.
Also the axle question.. depends really on what car the trans came from?
saemoonyang
11
Nov 3, 2011 12:33 PM
