best mpg?
Old Apr 26, 2004 | 11:42 PM
ef9one6's Avatar
Default best mpg?
thinking about swapping (B series) my crx just wanted to know which motor will give me the best mpg? any info would be great TIA....
Modified by ef9one6 at 8:56 AM 4/27/2004
Old Apr 27, 2004 | 12:36 AM
jedubz's Avatar
Default Re: best mpg? (ef9one6)
b16. Nuff said.
Old Apr 27, 2004 | 12:38 AM
drussell4801's Avatar
no no no
the actual answer is.....
**** MPG!
Old Apr 27, 2004 | 04:40 AM
davens's Avatar
I have this stupid little competition with myself...constantly top my best MPG.
I live just off the freeway and it's about 25 miles to, well, anywhere. So I do mostly highway driving.
I have a high compression B18b with Y1 lsd tranny, the standard bolt ons and lightweight 11lb Miata wheels in an 89 si.
By inflating my tires to 36 psi, driving real gentle(WOT is the enemy) and doing some light drafting I have gotten a personal best of 46 mpg. I can regularly produce low 40s though.
I'm about to go with the Exospeed mid range cams so MPG will take a slight hit.
With as much as gas prices are going up, it's a beneficial hobby
Old Apr 27, 2004 | 05:45 AM
crx_88_si's Avatar
Default Re: (davens)
[QUOTE=davens]and doing some light drafting QUOTE]
Man thats slick, until the guy infront of you slams on his brakes to miss a deer. then you're MPG goes to 0 cuz your cars folded like oragami paper.
Be careful...
Old Apr 27, 2004 | 08:53 AM
51mpgcivic91's Avatar
D15, Check your tire pressue , fresh plugs , clean air filter, no air conditioner speeds under 60 mph
Old Apr 27, 2004 | 09:15 AM
Mudge's Avatar
Default Re: best mpg? (51mpgcivic91)
I haven't played with pressures on this car yet, but normally on FWD and RWD cars I like more in front. I have gone as high as 38psi in the fronts and 34 in the rears, you should read the max safe pressure on your tires though (often 44psi), fill it on a day where the weather is somewhat normal because heat will increase psi and cold will drop it a bit. Obviously the heat is the worst because you can blow out a tire this way.
Skinny tires, lightweight wheels will help reduce rolling resistance also.
Like said above keep the speeds relatively low, cruise, speeding up and slowing down (like in California driving) will hurt the MPG a little. Look for whicever engine has the least HP and likely that will put out the best MPG. The HF 1.3L supposedly dumped out up to 67MPG on the freeway.
I commute 37 miles each way so I feel your motivation there, gas in CA is never under $2 these days, $2.13 for 87 is good.
Old Apr 27, 2004 | 09:29 AM
96-EJ6 B18C's Avatar
Default Re: best mpg? (Mudge)
Lat time I went on a trip and did the math I was getting about 37mpg out of my Si motor...and that was with a bit of playing too!
Old Apr 27, 2004 | 10:29 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9one6 &raquo;</TD></TR><TR><TD CLASS="quote">thinking about swapping (B series) my crx just wanted to know which motor will give me the best mpg? any info would be great TIA....</TD></TR></TABLE>
I'd say a B16A with a Y1 or an "LS" long-geared transmission would give you the best fuel mileage.
I can reach over 30mpg in my 2000 Civic Si, and that's a 2600lb car with a short-geared transmission. It's really all in your driving style . . .
However, if fuel economy is your prime concern, I don't see why you would bother swapping to a B-series at all.
Old Apr 27, 2004 | 11:21 AM
Fred.Rodgers's Avatar
I have gotten 39 mpg regularly on my stock si motor. My dad gets 46 on the highway regularly (old man syndrome) in his 01 LX 4door.
Old Apr 27, 2004 | 11:59 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
ouch i get about 25 around town and 30 on the highway with the zc.
Old Apr 27, 2004 | 12:57 PM
HF2ZC's Avatar
The D15b6 (HF engine) will definitely get the best mpg. I got 50mpg on the highway one time (flat ground, no a/c, 60 mph, synthetic oil) with it. The DX (D15b2) engine isn't bad either, giving about 35 mpg in mixed city / highway. B - series engines aren't too bad, most people report getting 25 - 30 mpg. You might consider the DOHC ZC, mine gets about 32 mpg in mixed city and highway driving with the Si transaxle and PG7 ECU.
Old Apr 27, 2004 | 01:52 PM
davens's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Be careful...</TD></TR></TABLE>
Uh, thanks...I hadn't thought of that.
Old Apr 27, 2004 | 08:35 PM
ef9one6's Avatar
Default Re: best mpg? (Targa250R)
thanks for the info mpg fuel economy is a concern of mine cause its my daily driver and i have a long drive to work, the reason for the swap is because my motors going bad and it would be nice to have the extra power when needed....
Old Apr 27, 2004 | 09:14 PM
CivicVX94's Avatar
i would think the d15z1 would get the best mpg i mean it is made for fuel efficiency and has 92 hp(max but hey there are less hp hondas) it's sohc v-tec E. i haven't done any research on it but i remember someone on h-t reported in the 50's, i don't know if i believe it but it's been said...
Catch 22
30
Dec 29, 2005 07:36 PM
Conechaser
Apr 24, 2002 05:43 AM
