SFWD Muffler, will this pass??
Would this muffler pass for NHRA SFWD rules??
Quoated from the rule book for SFWD:
"Exhaust:
All exhaust must flow through functioning muffler(s); must exit
behind rear tires. Any vehicle that did not come equipped with a
muffler(s) from the factory permitted, provided complete,
unmodified (except for header) OEM exhaust system is utilized."
Quoated from Summit Racing catalog:
"The sound of the '60s musclecar is back.
<U>Muffler</U>, Glasspack, Center 3 in. Inlet/Outlet, Round 14 in. Case, Bare Steel, Each
Our steel glasspack mufflers combine a louvered center tube with fiberglass packing to produce that powerful, distinctive glasspack sound. And with a free-flowing design, they'll help you deliver the power to back it up!
Put this under the shiftlinkage and then come out the rear with the reast of the tubing. Would make it alot easier with the room left after doing a sumped fuel system.
"Exhaust:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XXXRacing »</TD></TR><TR><TD CLASS="quote">yes sir, that is similiar to what i use, just a little smaller
Brian</TD></TR></TABLE>
What muffler do you use on your car? I saw a picture of the back half of your exhaust where it stops right after the rear axle but i cant tell what size it is.
Brian</TD></TR></TABLE>What muffler do you use on your car? I saw a picture of the back half of your exhaust where it stops right after the rear axle but i cant tell what size it is.
bboylito
May 7, 2006 05:08 PM
