Rear brake drum problem
Old Apr 26, 2004 | 08:59 PM
DJ0820's Avatar
Default Rear brake drum problem
ok, my crx sat for about 6+ months. I think it had a leak somewhere because the MC just had thick muddy fluid the very bottom of it and no real fluid when I opened it. SO I took the MC off and cleaned it up real good and shiny. I just replaced the rear wheel cylinders because i broke them trying to get the bleeder screw off and it ended up just braking the bleeder screw in half. So I put new fluid in after I change the pads/shoes and then i go to try to bleed the rear brakes now and no fluid comes out, and no air either. But when i had the rear lines disconnected, fluid was dripping out and forming good sized puddles on the floor. The front brakes bleed fine....whats my problem and how do I fix it? Help! I havent driven my CRX in 6 months and this is the last thing I have to do.
Later,
Derek
Old Apr 27, 2004 | 10:36 AM
DJ0820's Avatar
Default Re: Rear brake drum problem (DJ0820)
c'mon people, someone must know
Old Apr 27, 2004 | 12:55 PM
keithv's Avatar
It may take a while for the wheel cylinders to fill up with fluid and then for fluid to come out. I would keep pumping for a bit to see if fluid eventually comes out.
Old Apr 27, 2004 | 07:14 PM
DJ0820's Avatar
Default Re: Rear brake drum problem (keithv)
ok any more ideas?
Old Apr 28, 2004 | 05:20 AM
DJ0820's Avatar
c'mon someone has to have an idea
Old Apr 28, 2004 | 11:12 AM
UK CIVIC B16A2's Avatar
are you using a one way valve? if so you could try using a large vacuum pump on the nipple to draw the fluid out. pumping the pedal always works for me. or you could just open the nipple right up and leave it to drain for a while and let gravity work its magic
bay.kid
May 8, 2013 10:00 PM
D16SiHatch
11
Apr 28, 2011 08:00 PM
SPOOLINmatt
Honda Civic (2001 - 2005)
18
Mar 2, 2011 08:09 PM
jdmboy96
Feb 10, 2009 08:44 PM
vince37
Aug 8, 2006 06:16 PM
