D16y7 To D16Y8 & Turbo
Old Apr 26, 2004 | 08:59 PM
TurboHatch00's Avatar
Default D16y7 To D16Y8 & Turbo
I have all the parts for a mini-me swap but I also have a turbo kit waiting to be put in. I already did tons of searches, And I need to know how this would differ from doing one at a time? I realize i'm going to have to go into the engine for each project anyways, so why not do it all at once! If anyone can help me out, or if anyone has any links I could check or out, or even a topic i looked over I would really really appreciate it!
Thanks!
P.S. I've never done engine work before, but I feel I have all the patience to do a job well done.
Old Apr 26, 2004 | 09:26 PM
Archidictus's Avatar
Unceasing Measure
Default Re: D16y7 To D16Y8 & Turbo (XAllNewbX)
Well, the turbo should be a bolt-on affair aside from the couple of oil lines you need to run (at least one of which necessitates tapping the oil pan). I wouldn't consider it to be a blockade of any sort to your aspirations for a mini-me. Just get that Y8 head on the Y7 block and worry about turbocharging it later.
Old Apr 26, 2004 | 09:47 PM
Default Re: D16y7 To D16Y8 & Turbo (Archidictus)
So you mean I don't have to go into the engine when I turbo the car?
Thanks for reply!
Old Apr 26, 2004 | 09:53 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XAllNewbX &raquo;</TD></TR><TR><TD CLASS="quote">So you mean I don't have to go into the engine when I turbo the car?
Thanks for reply! </TD></TR></TABLE>
If you're looking into high-boost levels (12+ psi), you'll probably want to upgrade your pistons and rods. If you're planning on a more sane, street-friendly boost diet (6-10 psi), there's no reason you can't slap a turbo kit on a d-series, get a couple hours of tuning under your belt and drive the **** out of it. For examples, troll around in our forced induction forum for a while .
And you're welcome.
Old Sep 15, 2004 | 06:49 PM
ityab0y's Avatar
https://honda-tech.com/zerothread?id=554053
Clean2000Ex
Dec 14, 2017 09:40 AM
Belto741
Jul 26, 2017 10:47 AM
949
Apr 19, 2010 08:34 PM
fivelugsteelies
Jan 7, 2005 10:54 AM
Naturally Aspirated
52
Jun 13, 2003 07:48 AM
